21CN-Exchange-Availability checker
All Star
Fixes: 23
21 REPLIES 21
Plusnet Staff
Plusnet Staff
Fixes: 121
Re: 21CN-Exchange-Availability checker
Is this what you're looking for: https://www.samknows.com/broadband/exchange_search
From a phone number it can tell you what services are available at an exchange.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Fixes: 25
The SamKnows exchange checker has not been updated for the exchanges that have been more recently (within the last several months) upgraded for WBC ADSL2+.
The most authoritative and updated checker should be:
https://www.btwholesale.com/includes/adsl/adsl.htm
All Star
Fixes: 23
Thanks; neither SAM or Exchange Checker show 21CN available on my exchange, but PN have advised I'l be migrating to it soon, which should double my upload speed too possibly.
"Harry B said 'I've also noticed 21CN is available'"
So I assume they've got more up to date data set available to them; OR  link kindly provided does show:
There are no left in jumpers available on this line. This line is on a Market A Exchange.
There is an open order on your line which is due to complete by 27-Apr-2016.
Fixes: 62
All Star
Fixes: 23
All Star
Fixes: 23
My change to 21CN has made a substantial improvement in upload & D/load speeds;
surprised as I am on long line and at end of our village. (5.1 km by road from Exchange).
Heading in direction of 4mbps it seems Smiley  Smiley
And prior to this stability on line was really awful with several disconnections a day.
Product name:CN21 Plusnet Hub
2. Serial number: +081441+NQ54605093
3. Firmware version: Software version 4.7.5.1.83.8.217.1.1 Last updated 13/02/16
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 07:09:50
6. Data rate: 917 / 3395
7. Maximum data rate: 914 / 3640
8. Noise margin: 6.0 / 4.5
9. Line attenuation: 36.2 / 61.3
10. Signal attenuation: 35.7 / 56.4
Tags (1)
Fixes: 54
There's room yet for improvement on that SNRM!
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent.
Fixes: 417
Moderator's note by Mike (Mav)
I have reset the fix to Oldjim as it was his post that gave the required link.
Forum Moderator and Customer
Fixes: 54
OT: @jaread83
When Mav worked his magic, I saw a "Mav has accepted YOUR fix..." Flash message.  Is this on your lithium bug list?  I've also just discovered that the flash messages are clickable! Smiley
Fixes: 417
I wish clicking on a flash message would open it in another tab, thoughWink
Fixes: 54
@Townman wrote:
OT: @jaread83
Ooooo! Just realised that lithium did not self capitalise - when was this fix deployed? Funny
Fixes: 254
@Townman 12/04/16 Wink
https://community.plus.net/t5/Community-Site-Feedback/Priority-Forum-bugs-have-appeared/m-p/1325767#...
@HarryB wrote:
@Townman wrote:
Edit: Note I did not put the capital "L" in Lithium above (nor here) - do wish they would drop this self grandeur in presuming that any and all reference to the chemical element is intended to refer to their company name requiring it to be changed to a proper noun.
For what it's worth, I've done some digging around and found what's causing this. You should now be able to say lithium without it auto-replacing it with Lithium.
 Harry Beesley
 Plusnet Infrastructure Operations Professional
All Star
Fixes: 23
Speed test still shows upload at 0.3, whereas router 0.9 Sad
Why the big variance; far less variance on d/load, 3.6/2.7.
On cord phone line is quiet.
Tags (1)
Legend
Fixes: 168
Can you run a BT speedtest, doing the further diagnostics after the first test completes? http://speedtest.btwholesale.com/
