21CN ADSL2 - How can i tell?
- 21CN ADSL2 - How can i tell?
Re: 21CN ADSL2 - How can i tell?
24-01-2012 6:30 PM
24-01-2012 6:32 PM
thanks again
Nicksy
24-01-2012 6:34 PM
So can you please post the Current Line Speed as I requested
Quote from: Joanne Hi nicksy,
As Jim says, yes you have. I've just ran a check on your sync speed and set the profile on our side to 16400. You should see the increase shortly. The reason you hadn't seen the increase was because our system hadn't picked up the new profile as yet.
Jojo
24-01-2012 6:35 PM
24-01-2012 6:37 PM
Here is my example one:
High-speed Broadband
Telephone number:
01*********
Phone exchange:
CUCKOO OAK
Estimated line speed:
5Mb (This may vary between 4Mb and 8Mb) - Checked on 2011-12-17 22:16:03
Current line speed:
13.6 Mb
You need to look at the bottom one Current line speed and post back.
24-01-2012 6:39 PM
Phone exchange:
DESBOROUGH
7Mb (Accurate to within +/- 1Mbit) - Checked on 2012-01-04 10:08:05
Current line speed:
16.4 Mb
i will not be able to reply for afew hours i have to run out, but again, i thank you for all your help!
Nicksy
24-01-2012 6:44 PM
Two possibilities
The BT system has got itself in a tizzy
You are connecting to the router using wireless
24-01-2012 6:45 PM
24-01-2012 8:10 PM
24-01-2012 11:05 PM
before i was running tests on my main pc that is connected to the router via Wi-Fi. im not able to plug the main pc into the router with a cable sadly, but i was able to get hold of a laptop to test it out that way and the test results are better as follows:
so im thinking its a wireless issue? is there anything i can change on the router that might ix the problem? i have the tompson GT585 V7
24-01-2012 11:17 PM
24-01-2012 11:23 PM
25-01-2012 12:01 AM
25-01-2012 12:53 PM
25-01-2012 1:24 PM
I brought mine 30 Metre from this guy and it come next day, pretty fast!
