21CN ADSL2 - How can i tell?
- 21CN ADSL2 - How can i tell?
24-01-2012 5:13 PM
so again i as, is there a way of telling if i have been switched over yet?
Many thanks,
Nicksy
Re: 21CN ADSL2 - How can i tell?
24-01-2012 5:17 PM
24-01-2012 5:19 PM
24-01-2012 5:20 PM
As Jim says, yes you have. I've just ran a check on your sync speed and set the profile on our side to 16400. You should see the increase shortly. The reason you hadn't seen the increase was because our system hadn't picked up the new profile as yet.
Jojo
24-01-2012 5:32 PM
how long should i wait before i start to worry that my speeds are still the same?
im really not very good when it comes to routers and internet issues, so i have now idea how to check anything other then just doing a speed test, lol
24-01-2012 5:39 PM
do you know if thats the most i am likely to get as i assumed i would be getting somewhere between 11.2Mbps - 18.0Mbps?
Thanks again,
Nicksy
24-01-2012 5:42 PM
Can you post the result from the BT speedtest http://speedtester.bt.com/
24-01-2012 5:50 PM
24-01-2012 6:01 PM
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
5599 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 5599 Kbps
For your connection, the acceptable range of speeds is 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :18599 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 16409 Kbps
Upload Speed
707 Kbps
0 Kbps 888 Kbps
>Upload speed achieved during the test was - 707 Kbps
Upstream Rate IP profile on your line is - 888 Kbps
24-01-2012 6:04 PM
Your speed is still being restricted by this value for Current Line Speed at a guess https://portal.plus.net/my.html?action=data_transfer_speed
24-01-2012 6:13 PM
should i be expecting higher download speeds then the 8/9Mbps i am getting now?
sorry if i am coming across as stupid, lol and thanks for your help,
Nicksy
24-01-2012 6:16 PM
if so, then one of PN staff might have a look for you and put the correct profile set at 16.4Mb to match BT one.
24-01-2012 6:17 PM
24-01-2012 6:19 PM
24-01-2012 6:23 PM
thanks again for your help guys"
