1st BT Home Hub 2.0A worked with Plusnet, 2nd one won't!
- 1st BT Home Hub 2.0A worked with Plusnet, 2nd one ...
29-07-2011 2:56 PM
When my friend switched to Plusnet last year he acquired a brand new 'BT Home Hub V2.0 Type A' from another friend.
I tried it first, straight out of the box, with my own Plusnet connection and it worked perfectly. Then I gave it back it to him and it has worked perfectly with his Plusnet ever since.
I have now bought an identical BT Home Hub 2A on Ebay and I cannot get it to work with my Plusnet connection. It connects to the computer (wired or wireless) but not the web. Any ideas anyone?!
Message 1 of 3
(1,117 Views)
2 REPLIES 2
Re: 1st BT Home Hub 2.0A worked with Plusnet, 2nd one won't!
29-07-2011 4:45 PM
Hi Martineau,
Getting home hubs to work with other ISPs than BT usually involves a firmware upgrade.
If you search these forums I'm positive you'll find a post that points you in the right direction for that.
Message 2 of 3
(398 Views)
30-07-2011 3:55 PM
I'm pleased to report it's now working. I reset it back to factory defaults (again) and after a while it just connected and is now working fine. Thanks for your reply anyway.
Message 3 of 3
(398 Views)
