17KBs down 5KBs up!
- 17KBs down 5KBs up!
17KBs down 5KBs up!
09-06-2008 12:17 PM
Since first thing this morning I have seen a massive drop in speed. My modem is syncing at its usual rate (3.5Mbs), attenuation etc is normal.
I have disconnected and rebooted the modem (vigor 100) and the router (Buffalo HP 54G) to no avail.
My speeds are a consistent 125Kbps down and 27Kbps up (according to speed test linked to from portal).
I have seen the usenet post re off peak speeds and issues with low priority traffic however I am seeing low thruput on all protocols.
Are there any current issues that may be affecting me?
Message 1 of 4
(1,190 Views)
3 REPLIES 3
Re: 17KBs down 5KBs up!
09-06-2008 1:02 PM
I bet you've been subjected to BT Wholesale's Dynamic Line Management and your IP profile's been lowered.
What does a BT Speedtest say?
Message 2 of 4
(382 Views)
09-06-2008 1:29 PM
In fact, it looks like you've hit the usage allowance for your Broadband Plus product. Your billing date is tomorrow so your restrictions will be removed them.
It might be worth looking into the newer range of products we offer to see if they are more suitable, the main point to remember is that the peak times run from 8am-Midnight on the new products.
Message 3 of 4
(382 Views)
09-06-2008 5:28 PM
Thanks Chris & Bob.
Sorry about that I should have checked more carefully. I did view my usage but for some reason I thought peak limit was greater than 4GB. Has the peak allowance been amended for BB+?
Anyway thanks for the quick responses.
See you back in nntp:plusnet.service.customer-feedback 😉
Message 4 of 4
(382 Views)
