128 kbps Only on an upto 8mbps connection
- 128 kbps Only on an upto 8mbps connection
17-03-2008 10:17 PM
Plusnet don't know why I have this pitiful download speed.
Anyone have any ideas?
Re: 128 kbps Only on an upto 8mbps connection
17-03-2008 10:33 PM
Can you post a BT speedtest result so we can see sync rate, IP profile and data throughput rates?
18-03-2008 9:41 AM
I've checked from both our and BTs end to see how your line is being profiled. From a traffic management perspective, your line is being profiled as it should be for your product and you haven't exceeded your usage allowance. From the BT end, you're on a 2500Kbps profile, so you shouldn't be seeing the speeds that you are!
I would be grateful if you could run a BT Speedtest to see whasort of results that gives.
http://www.speedtester.bt.com
21-03-2008 3:35 PM
Details are (taken on the 21 march 2008)
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 750 kbps
DSL connection rate: 448 kbps(UP-STREAM) 896 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 609 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
21-03-2008 4:37 PM
This link explains how to get them http://www.kitz.co.uk/adsl/frogstats.htm
21-03-2008 8:49 PM
Quote from: aw14 Test1 comprises of Best Effort Test: -provides background information.
BT's Dynamic Line Management kit has reduced the throughout off your line to 750kbps
Quote DSL connection rate: 448 kbps(UP-STREAM) 896 kbps(DOWN-STREAM)
You are only synchronising with the exchange at 896kbps. Whilst it's like this you're download speed will not increase. Try rebooting your kit to see if this value increases.
Quote Actual IP throughput achieved during the test was - 609 kbps
If the reboot increases your sync speed and you remain connected at a higher rate, then your download speed should increase again after a few days.
21-03-2008 9:37 PM
If so, what has been changed since it was good, and how good was it?
22-03-2008 1:44 PM
Details required are as follows:
ine Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 03:07:46:19
Line Coding Trellis Off Line Up Count 11
Statistics Downstream Upstream
Line Rate 896 Kbps 448 Kbps
Noise Margin 25.6 dB 15.0 dB
Line Attenuation 37.0 dB 21.0 dB
Output Power 16.4 dBm 11.8 dBm
22-03-2008 1:45 PM
I am new to this and it as been better but nothing as changed - in the house. Could it be possible the free router I was given is faulty?
Thanks to all.
Aw
22-03-2008 2:07 PM
If there's a fault it could be in lots of places, though the router is maybe one of them. As is your wiring, the filter(s), phone line, exchange equipment etc.
Have you used Kitz' Broadband Availability Checker at www.kitz.co.uk ?
Enter your phone number and postcode and it gives you an estimate of your potential speed and distance from the exchange etc. Post the results back here please.
With the attenuation shown you are maybe 2.5Km (is that right?) from the exchange and should in theory get up to 6Mb or even 7Mb speeds.....
22-03-2008 2:13 PM
What does this mean?
22-03-2008 2:19 PM
Info requested:
Exchange: Earl Shilton. BT Code: EMERRSS
ADSL enabled : March 30, 2001
dsl Max enabled: March 30, 2006
SDSL enabled : Not Enabled
21CN due : no info
Distance:- Direct: 1.52 km
(appx)* By Road: 1.61 km
BT Line Speed Estimation Other Broadband Technology & LLU Providers
adsl button Fixed ADSL: 2048 kbps (2 Mb)
adsl button DSL Max : 4000 kbps (4 Mb)
Important: The above figures are an estimate based on information obtained from the BTw database.
DSLmax speeds are best guess based on the surrounding area and cannot take into effect individual line conditions which may effect the result such as the type of equipment you use or other issues which may affect the Signal to Noise Ratio.
You may also be interested in Max dsl speed calculator
AOL Not available
Be* Available 29.04.07
C&W/Bulldog Not available
Edge Telecom Not available
Homechoice Not available
Lumison Not available
NewNet Not available
Node4 Not available
O2 Available 29.04.07
Orange Not available
Pipex Not available
Smallworld Not available
Sky Not available
TalkTalk Available
Tiscali Available 25.07.07
UK Online Not available
WB Internet Not available
Zen Not available
Cable
Virgin Media Available
Smallworld Media Not available
Wireless
LTT Broadband Not available
Now Wireless Not available
RAG Test Results
Fixed: 1Mbps and 2Mbps available
radsl: 512Kbps and 256Kbps available
MAX: ADSL Max is available
SDSL: Exchange Not Enabled
TPON: TPON/Fibre not recorded
Check: The check identified another service on your line which may prevent you from ordering a new ADSL connection. Examples are : Existing adsl connection, DACs, LLU, TPON
adsl 1 linecode : GGEC
dslmax linecode: GEGEGEC
sdsl linecode: 1111GGGAZZZZNNNN
[Moderator's note by Peter (PJ): As this forum is visible to search engines and the general public I have removed your location details for your privacy]
22-03-2008 2:55 PM
Definitely time to call PlusNet, though I did read somewhere that they have a dedicated "speed issues" team that are not around 24*7, so you may have to wait for in-depth investigations.
They'll probably start by asking you to plug in your router & filter at the BT master socket having disconnected all internal wiring by removing the faceplate. Might as well try that yourself if you know how and see if the sync speed improves..
22-03-2008 10:55 PM
Whilst it could be many other things, I'd recommend taking a very careful look at whether you've got a faulty filter, a device on the line without a filter, or any part of your phone line running close to a source of interference.
1.5km from exchange ought to give at least 4Mb...
25-03-2008 10:43 AM
Quote Noise Margin 25.6 dB
That's the worrying bit. I'd try changing your filter and making sure that you are connected directly to the master socket via that filter and that all of your used telephone sockets have a filter connected to them.
When Bob talks about DLM, this is BTs profiling system that they use to profile connections based on the connection speed with the exchange.
