11.00am and speed no higher than 450kbps
- 11.00am and speed no higher than 450kbps
08-10-2009 11:21 AM
Re: 11.00am and speed no higher than 450kbps
08-10-2009 11:27 AM
08-10-2009 11:31 AM
Peak usage: 122.66MB 4pm - Midnight
Off-peak usage: 2.73GB Midnight - 4pm
HTTP downloads from various websites
08-10-2009 11:46 AM
08-10-2009 11:51 AM
Do speeds improve after a reboot? It's unlikely (but not impossible) for it to be our network causing those problems at this time of the day.
What sort of download are you trying to do, or is it just a speed test?
08-10-2009 11:59 AM
....and now suddenly, as if nothing was wrong, that's what PN's speed test shows I'm getting! It's the inconsistency that's the problem as clearly I can still get a proper speed some of the time.
A few minutes later:
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/05323006.png" /></a>
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/05323020.png" /></a>
08-10-2009 12:02 PM
Have you tried rebooting as per my previous post?
08-10-2009 12:03 PM
Tried both - no change.
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/05323113.png" /></a>
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/05323127.png" /></a>
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/05323148.png" /></a>
08-10-2009 12:23 PM
<a href="http://www.mybroadbandspeed.co.uk"><img src="http://www.mybroadbandspeed.co.uk/results/05323210.png" /></a>
08-10-2009 1:31 PM
Your speeds are perfectly acceptable - fluctuations are to be expected via exchange congestion. You are correct in that you have an extended off peak period - however, I believe that the problems you are seeing a re exchange based rather than on our network.
08-10-2009 4:44 PM
To tell the truth if it wasn't affecting how I can use the internet connection I'm paying to use it would be laughable!
On mine, everyday the speed varies from <500kbps to my normal 5900kbps within the space of a few minutes and on the same router session. This is happening no matter the time of day or night, and for Plusnet to say it's a contention issue when it's also occurring in the early hours, i.e. 3am-5am, is a joke.
08-10-2009 9:36 PM
For example:
Have all recent changes to traffic management been reviewed to see if they might be the cause?
Has there been any dramatic drop in traffic totals recently which might suggest a cause?
What kind of problem might cause the commonly reported wildly fluctuating instantaneous download rates?
I want to see evidence that PN are whole-heartedly investigating why this is happening - ideally via daily status reports - and that might just persuade me to remain a customer until it gets fixed, but without evidence that PN are really trying to sort the problem, I'll be off soon. I'm paying £15 a month for a service which is dire at the moment with web pages sometimes taking up to 5 minutes to load.
vof
08-10-2009 10:08 PM
I understand your frustration, let me catch up with James and see where he got to with this and we'll get an updated in here tomorrow.
09-10-2009 8:55 AM
I'm sorry for your (and Azagoth's) frustration.
Quote Have all recent changes to traffic management been reviewed to see if they might be the cause?
Firstly, there haven't been any recent changes in traffic management and we're not seeing a drop in traffic being reported. However, with our traffic management approach, it's rare that we would - the network is designed to always run at capacity until off peak. As to what might cause the problem I'm really not sure. AAISP are reporting that they are seeing a drop in traffic which is potentially pointing towards generic exchange issues, however, they are always extremely quick to point the finger to blame BT.
I'm not going to post a service status with daily update because we're seeing a limited (and yes, it is a limited number) of customer reported what appears to be exchange based congestion. Azagoth - It's probably best raising your issue as an EPP (End-user poor performance) fault to BT. Can you possibly get me a list of BT Speedtest results together, coupled with everything else you have tried at your end into a ticket and I'll look at raising with BT *if* the speed results are below what BT deem unacceptable.
09-10-2009 9:13 PM
Should I also raise a ticket including all my actions and test results?
vof
