1000 hour PPP session - is this a record?
- 1000 hour PPP session - is this a record?
07-03-2013 1:42 PM
Well almost certainly not a record but I thought a connection time of over 1015 hours was noteworthy. This is recorded by my Netgear router, which I previously established resets the clock whenever a new PPP session begins. Some while ago there was a thread on whether PPP sessions have a lease time. Considered opinion is that they do not and my evidence would seem to support that.
Message 1 of 8
(1,348 Views)
7 REPLIES 7
Re: 1000 hour PPP session - is this a record?
07-03-2013 1:53 PM
PPP sessions have a lease time<<< i hope this is not the case because i do not want my net to keep changing on its own and it never did this on my o2 adsl2+ connection, I had uptimes of months inless i restarted the router.
Message 2 of 8
(523 Views)
07-03-2013 2:07 PM
When I was on the old fixed speed 2mbit connection on IPstream, my then router would only drop connection when I rebooted it after 6 weeks. If I left it too long it would eventually crash
FTTP 500 regrade from Tues 28th November
Message 3 of 8
(523 Views)
07-03-2013 3:31 PM
I had around 200 days of uptime with BE with no disconnects. The router was on a UPS too so not sure if that helped.
Message 4 of 8
(523 Views)
07-03-2013 3:44 PM
If they did have some sort of "lease time", I would think there would be some facility to renew or extend your current lease.
Message 5 of 8
(523 Views)
07-03-2013 9:37 PM
Let's be clear, I do not believe PPP sessions have a lease time. 1015 hours is over 42 days (six weeks) so I have a long way to go before reaching picbits' 200 day record.
Unfortunately, although I have a UPS, it does not respond fast enough to prevent my router from briefly disconnecting in the event of a power cut.
Message 6 of 8
(522 Views)
07-03-2013 9:53 PM
That seems a bit of a fundamental fault, having a UPS that isn't fast enough to maintain it's own output on a power drop !
What model is it ?
What model is it ?
Message 7 of 8
(523 Views)
07-03-2013 11:46 PM
Quote from: picbits I had around 200 days of uptime with BE with no disconnects.
My Be connection is currently at 850 hours which is nothing remarkable at all. Only 35 days.
I vaguely recall having to unplug it for some reason at the end of January.
I've seen it around a year before now.
It's running DGTeam firmware which seems to be more stable than the vanilla Netgear it would otherwise have.
Message 8 of 8
(523 Views)
