10.30pm and still laggy
- 10.30pm and still laggy
24-07-2016 10:34 PM
from 6.00pm and up to 10.30pm nothing but lag
if I lagged anymore I would find myself in Narnia while playing BF4
Message 1 of 3
(636 Views)
2 REPLIES 2
Re: 10.30pm and still laggy
25-07-2016 11:01 AM
Testing your line isn't showing any issues at all, can you advise how you're connecting? Is this wired or wireless? Do you have any problems with other online services or just gaming?
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 66.9 Mbps |
Upstream Speed | 20.0 Mbps |
Message 2 of 3
(591 Views)
25-07-2016 12:21 PM
its all good Im using the "phone" options to sort this so far a static IP is the next step
Message 3 of 3
(575 Views)
