10.2.5.2.EO and 10.2.5.2.FO
- Re: 10.2.5.2.EO and 10.2.5.2.FO
09-03-2014 4:10 PM
What are the differences in these firmwares for the TG582n FTTC?
Thanks.
Thanks.
Message 1 of 2
(876 Views)
1 REPLY 1
09-03-2014 6:33 PM
Configuration changes to enable multicast support for Plusnet TV. See http://community.plus.net/forum/index.php/topic,121504.0.html
The only changes between EO and FO are to the default configuration and to the web interface of the router.
Also added "gracefulrestart" to the PPP configuration.
diff -Nur 10252eo 10252fo | diffstat
WWW/include/heading.lp | 29 +++++---
WWW/include/top_piece.htm | 35 +++++++---
WWW/info.xml | 14 ++--
WWW/webpages/advanced.lp | 7 ++
WWW/webpages/b_menu.js | 2
WWW/webpages/images/testred.gif |binary
WWW/webpages/isp.lp | 2
WWW/webpages/landing.lp | 39 ++++++++++-
WWW/webpages/landingredirect.lp | 18 ++++-
WWW/webpages/relflib.js | 16 ++++
WWW/webpages/remote_admin.lp | 25 +++++--
WWW/webpages/setpassword.lp | 2
WWW/webpages/setup.lp | 137 ++++++++++++++++++++++++++++++----------
WWW/webpages/wlan_device.lp | 2
igmp.def | 7 --
mstroot.pem | 26 -------
ppp.def | 1
upgrade.sts | 53 ---------------
18 files changed, 259 insertions(+), 156 deletions(-)
--- 10252eo/archive/XXXXXX10.252/active/igmp.def 2013-05-09 14:51:20.000000000 +0100
+++ 10252fo/archive/XXXXXX10.252/active/igmp.def 2013-11-04 14:52:26.000000000 +0000
@@ -1,5 +1,4 @@
ifconfig intf=LocalNetwork state=downstream version=IGMPv3 fastleave=disabled
-proxy config state=enabled
-proxy ifconfig intf=Internet state upstream
-proxy ifconfig intf=Multicast state upstream
-proxy ifconfig intf=LocalNetwork state downstream
+ifconfig intf=Internet state=upstream
+ifconfig intf=Multicast state=upstream
+config state=enabled
ifconfig intf=Internet gracefulrestart=enabled
Message 2 of 2
(430 Views)
