0.79 down speed
Anotherone
Fixes: 21
Re: 0.79 down speed
Those system log entries are odd. Do you have any customised setup or changed anything since sorting it out when Jaggies posted about it?
alliasjay
Re: 0.79 down speed
Haven't touched a thing since it's been set from Jaggies post.
Would try checking out the event log again but can't even log into the router. just hanging at 'waiting for 192.168.1.1'.
I'll post it again when it lets me in.
Current line speed:2.3 Mb  (a slight drop which hopefully is a good thing)
Download speedachieved during the test was - 2.22 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.46 Mbps
I'm happy with those results, just need to be able to log onto the router to see those stats. I would rather not have to reboot the router unless needed. I'll check after I've made food (fingers crossed its working by then)
Anotherone
Fixes: 21
Re: 0.79 down speed
You could try emailing TP-Link Support with those log entries and see what they say.
alliasjay
Re: 0.79 down speed
My phone line has been down for 1 day... They sent out a bt engineer which has connected it again.
So now my bt wholesale tests are coming up with 1.3mb again... woohoo
BT
1. Best Effort Test:
Download Speed : 1.32 Mbps
2. Upstream Test:
Upload Speed : 0.39 Mbps
PlusNet
Current line speed:1.5 Mb
Router
Downstream Upstream
SNR Margin
8.1       4.6 db
Line Attenuation
61.3       38.2 db
Data Rate
2137       584 kbps
Max Rate
2524     588 kbps
CRC
87 0
Anotherone
Fixes: 21
Re: 0.79 down speed
What time of day was it reconnected?
I'd pull the power plug (bearing in mind you haven't got a Disconnect button for the PPP Internet session) and stay off for 10 minutes and then power up again. Post the new stats.
alliasjay
Re: 0.79 down speed
It was reconnected this morning around 10am.
BT
Download Speed : 1.47 Mbps
2. Upstream Test:
Upload Speed : 0.44 Mbps
plusnet
Router
Downstream Upstream
SNR Margin
7.5      5.1 db
Line Attenuation
63.0      38.2  db
Data Rate
1881      659  kbps
Max Rate
2040      640  kbps
CRC
15 0
Anotherone
Fixes: 21
Re: 0.79 down speed
Well that certainly didn't seem to help Sad  The line is completely noise free is it? I wonder if your Target SNRM has gone up? We'll have to get a kind CRT person to look.
btw, did you ever check out that extra cable that you thought went next door?
Acassim
Re: 0.79 down speed
Hi All,
It looks as though something changed on the 2nd as the Target SNRM is set to 6 Up and 6 Down but according to the KBD testing the line is sat at 6 Up and 3 Down at the moment. On the plus side, the DLM has pushed the speed up to almost 1.7mbps from the 1.2mbps it was at previously so it seems to be recovering from the drop of the phone service.
An SNR reset may well be in order however I would be a little hesitant to place this at the moment given that the speed seems to be recovering.
Anotherone
Fixes: 21
Re: 0.79 down speed
Thanks for the info.Adam. I'd agree that an SNR Reset may not be a good idea right now, sync speeds circa 2400/2500 had been achieved with relatively little problem before this phone line fault. I'm suspicious that the line hasn't been repaired properly  Shocked  especially with an SNRM down at 3dB atm when the target is at 6dB.
@alliasjay, remind us who your line rental is with?
ListerofSmeg
Re: 0.79 down speed
My mate Alilasjay is busy but confirmed his line rental is only with Plusnet, we're a bit confused at the question tbh as his phone/broadband is with Plusnet
Anotherone
Fixes: 21
Re: 0.79 down speed
I didn't have time to re-read the thread to see if it had been mentioned. That's not a problem, if line rental is with Plusnet then they'll have to revisit this if as I stated I suspect that the line repair has not been done properly or there is still an additional problem with the line.
I think the next move should be run a quiet line test (17070 option 2) if it's still noisy get back to Plusnet, but it might be good to try a mid-day power down for 10 minutes then resync and see if a better speed can be achieved.
ListerofSmeg
Re: 0.79 down speed
hi there, I just did the quiet line test for him & there was no noise at all. I believe Alliasjay has also disconnected the line for 10 mins yest afternoon. He'll need to do a speed test though as I don't have that info
Anotherone
Fixes: 21
Re: 0.79 down speed
Best wait for stats then to see if it's any better.
ListerofSmeg
Re: 0.79 down speed
Alliasjay did a speed test lastnight and on BT is was showing 1.5Mb and the profile set as 1.6Mb
Oddly, on http://dslchecker.bt.com he has significantly improved: WBC ADSL 2+ Up to 3 -- 1.5 to 5.5 Available but the actual speed is still low
Anotherone
Fixes: 21
Re: 0.79 down speed
The modem/router DSL stats are really the thing that will give a clearer picture of what the current situation is - or someone from CRT running a quick Broadband test and posting all the figures.
