0.2Mbs Broadband Speed
FIXED- Subscribe to RSS Feed
- Re: 0.2Mbs Broadband Speed
02-02-2017 10:59 AM
I'll order the router now, it's sent first class so if it gets dispatched tomorrow it should arrive a couple of days later.
02-02-2017 4:26 PM
Thanks Chris, I received a text today to say it is on it's way. Thanks for your help.
06-02-2017 11:24 AM
Thanks - received the router on Saturday.
Also got a vague BT letter regarding an order number, which I guess is related.
i assume I'll know when the change happens, as the ADSL connection router we have here now will then stop working, and then I'll just have to swap the boxes over.
07-02-2017 8:36 PM
Let us know if you have any problems.
16-02-2017 12:54 PM
I noticed the ADSL router was still working, but I swapped it with the Hub One, left it to do its thing then connected.
I notice I am still getting ADSL speeds, so am I correct in assuming, the Hub One is just using the ADSL, Plusnet have completed the changes their side and now I have to wait for BT Wholesale to do theirs? Do they both usually happen on the same day? (i.e. today).
Sorry for being inpatient, you know what the wait is like, all of you 😛
Mind you I notice the Hub One even gives me faster ADSL speeds than my old router. When I checked I found Plusnet supplied me the Thompson router in 2010. 7 years ago! Doesn't seem like that long. So I guess it was getting on a bit so I was due for new more modern one.
16-02-2017 1:01 PM - edited 16-02-2017 1:02 PM
The order of events is that Openreach do the work by moving your phone line off ADSL and connecting you to the FTTC cabinet. Then BTW setup the account for FTTC and finally Plusnet complete their work.
At that point you will be on FTTC.
As the Hub is connecting at ADSL speeds, you are probably still on ADSL at this moment. The line can only support ADSL or FTTC not both simultaneously.
The work can be completed any time upto midnight.
16-02-2017 1:04 PM
Once the engineer completes the work at the cab I'd expect you to connect at the fibre speeds.
16-02-2017 1:06 PM
If you want to confirm that you are still on ADSL then the following will help.
Log onto the Plusnet Hub One Router and go to the Troubleshooting Section (top right corner). Once there click on the Helpdesk tab.
Look for the line starting
23. Modulation:
And then compare the code to the table below,
ADSL1 ADSL2 ADSL2+ VDSL VDSL2 Standard G.992.1 G.992.3 G.992.5 G.993.1 G.993.2
If the code is for ADSL then you haven't been upgraded to FTTC yet. If it is VDSL then you have been. Let us know what it says.
16-02-2017 1:23 PM - edited 16-02-2017 1:24 PM
Thanks for the check, I'll be back there in a few hours so will try it.
Never had BT Wholesale fibre so not quite sure what the process is. I actually walked up to the cab at the end of the street and saw a BT Wholesale van milling around near the cab and drove off so hopefully they are doing something. Bit sad I know.
Roll on midnight 😄
16-02-2017 2:12 PM
So hopefully you'll be connected by the evening!
16-02-2017 2:20 PM
16-02-2017 3:04 PM
Will keep checking later on 😛
16-02-2017 6:38 PM
Not a fault then as back up now, mum reports the big light as blue, so all good and I will let you know later. 👍
16-02-2017 9:30 PM
Changed over now and everything seems fine.
05-01-2018 10:15 AM
Hi, I,m currently having issues with complete broadband speeds across the board,
download speeds are at 0.22mbps and uploads are at 0.43mbps, this is causing issues to the whole family as wanting watch videos on popular sites etc, this has been raised before and improved slightly but since Christmas this has dropped to near nothing and not acceptable. Please look into this and see if you can help
Regards
Terry Walton
