0.11mbps DOWNLOAD SPEED
- 0.11mbps DOWNLOAD SPEED
Re: 0.11mbps DOWNLOAD SPEED
01-02-2013 12:19 PM
changed the filter
same speeds all round
looks like gonna have to get a man with a ladder out
01-02-2013 12:50 PM
01-02-2013 12:58 PM
Quote from: baileytech same speeds all round
I don;t know if one can tell from the figures you quoted but at that low a speed you might have been placed on a banded profile. If so, if you find and remove the fault your speeds will go up around 3 days later. But the attenuation reported by your router should drop immediately.
01-02-2013 3:08 PM
01-02-2013 4:02 PM
Correct. Also worth noting is the upload sync rate, it's very low which could indicate a potential issue on the BT Network.
@baileytech
I've tried to call you this afternoon, if you could just reply to the SMS I've sent, we'll get something arranged for you.
01-02-2013 4:34 PM
Quote from: Anotherone It's not a Banded profile causing the problem.
Excellent. I just remember from experience that you can completely cure a broadband problem yet see absolutely no immediate effect on the speed - which I'm sure must cause a lot of confusion. So I worry about banded profiles, the situation where this happens.
01-02-2013 10:51 PM
got an engineer booked to take a look on tuesday afternoon
lets hope he can wave his magic wand and sort it out
03-02-2013 7:38 PM
03-02-2013 9:01 PM
<puts hands in air>
ok ok you win !!!
03-02-2013 9:58 PM
We should start a competition thread on who has the slowest Plusnet connection !!!
Hope yours gets sorted
05-02-2013 4:48 PM
he was the nicest guy ever, he told me loads of interesting technical things and answered all my stupid questions - he spent a total of three hours in the house and in the box !
all tests in the house came back ok
he went to the green box and did more tests, turns out the pair of wires we are using are really old and not the best so he moved us on to a new pair and now the sync speed is 4756kbps (fastest in the village)
download speed is still abmissable but said that will catch up within the next few days
he said he will report back to plusnet, and said plusnet could even do something remotely with an ip profile can speed this process up
overall a happy bunny, even happier once the download speed sorts itself out
yay
06-02-2013 1:40 AM
Copy and paste the results in a post here. Hopefully someone from the DCT will then update your Current Line speed (Login required) to match the BT IP profile.
06-02-2013 7:55 AM
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
Additional Information:
Your DSL Connection Rate :4.77 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.25 Mbps
06-02-2013 8:54 AM
06-02-2013 6:23 PM
IP Profile for your line is - 0.14 Mbps
