0.11mbps DOWNLOAD SPEED
- 0.11mbps DOWNLOAD SPEED
30-01-2013 6:12 PM
Re: 0.11mbps DOWNLOAD SPEED
30-01-2013 6:28 PM
Firstly welcome to our community forums.
I've checked your account and line and everything looks fine.
Are you currently connecting wired or wireless?
Chris
30-01-2013 8:45 PM
both the same results
30-01-2013 8:59 PM
same slow speed
driving me crazy
30-01-2013 9:03 PM
I'm really sorry to hear that you are suffering with such poor speeds.
Could you provide us with a little more information such as your Line Stats: http://www.plus.net/support/broadband/hardware/technicolor-582n-faqs.shtml#lineStats
The more we can see, the better
31-01-2013 6:38 PM
0 drops in last 24 hours
14 drops in last 72 hours
13 of 15 (87%) User Req Drops in last 7 days
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 32.5 58
SNR Margin: 8 7
Errored Seconds: 0 0
HEC Errors: 0 0
Cell Count: 58195608 867406702
Speed: 160 192
Maximum Stable Rate (KBPS): 6240 Fault Threshold Rate (KBPS): 4992
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 86400
Indicative Line Quality: G Mean Time Between Errors Downstream (Seconds): 21600
TAGS: 1-3.5Mb
Pkts Errs Drops Pkts Errs Drops
- 0/38 PPPoA 24200 0 0 20209 0 0
- 0/65 RFC 1483 0 0 0 824 0 0
LAN Statistics
Interface
Received
Transmitted
Bytes Pkts Errs Drops Bytes Pkts Errs Drops
Ethernet 987371 5977 0 0 5980909 6665 0 0
Wireless 4225933 29496 975 975 14881966 21596 191 191
ADSL Statistics
Mode: G.DMT
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 320 kbps 96 kbps
SNR Margin (dB): 6.5 8.0
Attenuation (dB): 63.5 31.5
Output Power (dBm): 15.0 12.5
Super Frames: 72505 72505
RS Correctable Errors: 17 0
RS Uncorrectable Errors: 0 0
HEC Errors: 0 0
Total Cells: 49372 53464
Data Cells: 180469 53464
Bit Errors: 0 0
31-01-2013 8:29 PM
If all this draws a blank then there is most probably a fault on your line. Can you hear noise on the line if you listen to the dial tone or dial 17070 option 2?
31-01-2013 10:04 PM
changed the filter
connected router to bt test socket
connected via wireless and wired to pc, latop and iphone
same download speed
above stats are after done all the above
i have been with plusnet about 2 months and its never been right, was disconnecting all the time for the first month then second month got slower and slower
its driving me nuts
31-01-2013 10:10 PM
Thank you for completing the checks you've listed there and for providing your router stats. I'll get this issue picked up for you first thing in the morning and see what I can do to help.
31-01-2013 10:25 PM
31-01-2013 11:41 PM
Quote from: baileytech i have been with plusnet about 2 months and its never been right
The figures say differently. You wouldn't have an MSR of 6240 kbps unless it was vastly better throughout your initial 10-day training period. It must have gone wrong shortly after that.
Did you try another cable between the router and the socket? Did you listen for audible noise on the line?
01-02-2013 12:54 AM
Quote from: baileytech changed the router
changed the filter
same download speed
your download speed won't change immediately, it's the sync speed (connection speed, downstream rate) from your stats that you need to look at when making changes. When this improves, your BT IP profile will improve to match but the Plusnet Current Line speed (Login required) needs to catch up which can take several days as the BT Delta Report is not always sent out to Plusnet by the BT systems in a timely manner.
Judging by the stats you've posted, something has changed quite dramatically as you wouldn't get that MSR with the attenuation from the Plusnet tests or the attenuation reported by the current modem/router - so it looks as though you have some sort of external fault on the line or at the exchange provided those stats were taken whilst you were plugged into the test socket and whilst you are, you should check that any fixed extension sockets are all dead. As RR mentioned it's always worth checking the lead from modem/router to filter, I've seen similar problems to this caused by a faulty lead. Also any noise on the line (run the quiet line test if need be) will mess up the broadband and needs to be reported as a phone fault. If your Line Rental is with Plusnet, I'm sure Chris Pettitt will deal with that for you.
I assume that you didn't make any changes to your setup after the first few weeks, and that everything connected is plugged in via Microfilters that look like this that includes Sky boxes and the likes.
HTH.
01-02-2013 7:39 AM
during the first 10 days or so i had a lot of lost connections i put this down to the service being a bit unpredictable in this period, this continued until i felt the need to call plusnet, they suggested that it was my router that was the problem, so i changed it. things werent too bad for a while, but since then then speeds have got less and less and last week i was getting good reliable speeds and then suddely one day it ground to a halt and now i even have trouble loading this site
i will replace the cable see if that helps
thanks
01-02-2013 8:07 AM
01-02-2013 10:00 AM
