Plusnet Protect Problems (McAfee).
- Plusnet Protect Problems (McAfee).
05-10-2015 1:26 PM
I think there was a programme update (as opposed to a definitions update) recently.
Since then the following problems have occurred, the programme does not update correctly - before I had a blue notification box pop up telling me the programme has updated on the bottom right of my screen. This does not happen any more, I just get a small blue circle hanging on the McAfee icon in the taskbar & I have to open PP for the update to continue.
Also the McAfee firewall keeps turning itself off on it's own & I have to go into the programme again to switch it back on.
Windows firewall is switched off so there shouldn't be any clash.
I am running Windows 10 & these issues didn't appear until the latest programme update.
Any ideas please?
Re: Plusnet Protect Problems (McAfee).
05-10-2015 6:19 PM
its personal preference , some here will say the same McAfee is not the best and uninstall for another AV
13-10-2015 9:45 AM
I have also seen warnings about the McAfee firewall being turned off (usually when starting Google Chrome), but it hasn't happened very often, and as it restarts as I continue with Google Chrome, I haven't been too concerned.
13-10-2015 5:44 PM
I've tried Windows 10 and found it impossible to load Plusnet Protect and could only get Comodo internet security to work with the greatest difficulty. I've since gone back to Windows 7 and peace and serenity have been restored!
For the time I used Windows 10 I got the impression that it was designed to make it as hard as possible to use non-Microsoft programs - maybe I'm seeing a conspiracy where there isn't one!!
Jon
13-10-2015 6:35 PM
I have now realised it is happening on at least two Windows 10 machines in my house.
Always used to get a blue notification message on the lower right of my screen when McAfee updates were installed, but no more. Of the issues mentioned, the firewall switching off one is of some concern.
As this is a P/N provided programme as part of my package I think they should look into it!
13-10-2015 7:00 PM
It says the subscription has run or about to run out (thought Plusnet Protect was ongoing).
Also mentions the update problem as well.
My computer clock is ok.
Yes Windows firewall is off, surely you are not supposed to run more than one firewall at once?
Some serious problems here which need sorting asap.
15-10-2015 12:50 PM
15-10-2015 5:48 PM
I haven't used MVT before, but I don't think it is telling buseng12 that there are lots of problems. Just the one highlighted in red (subscription running out)? I think the other issues are just examples of other common issues that could occur?
I'm still getting the problem with the automatic updates getting stuck though.
15-10-2015 8:04 PM
https://community.mcafee.com/community/home
The current build is 4121 & a new build, 5084, is supposed to be coming out to solve it.
When we will receive it is anybody's guess?
The current beta build has the fix.
18-11-2015 10:45 AM
18-11-2015 1:29 PM
To be is to do - Kant
do be do be do - Sinatra
18-11-2015 2:37 PM
So ... I have PlusNet protect (McAfee) installed on several home machines running different versions of Windows: Vista, 7, 8, 8.1, and all exhibit the same behaviour:
The PlusNet protect icon on the system tray area will show the grey box informing that an action is taking place.
Hovering the icon, shows an update is underway. However, the update never completes. The only recourse is to launch McAfee and open the Update panel. The update will then run immediately.
I'd classify this as an "annoyance" rather than a fault, but any advice is welcome.
PlusNet, prove that you're monitoring this forum and post some useful advice!
20-11-2015 9:53 PM
my serious advise with regard to mcafee would be to ditch it at this point and use something else unless your prepared to constantly be needing to completely remove and then reinstall it, the program currently doesn't seem fit for purpose, I'll likely try it again in the future on a spare machine if for no other reason than to see if the problems of the past have been fixed, after all it was a very simple to use and effect program before it started to go completely pete tong
