Is your USB safe
- Is your USB safe
Is your USB safe
31-07-2014 7:15 PM
so it looks like its wise not to trust anyone's USB connected device
Re: Is your USB safe
31-07-2014 7:23 PM
31-07-2014 7:43 PM
If it happens.... it happens... not much you can do about it,... so stop worrying about it, .... and enjoy life as it comes.....
31-07-2014 8:53 PM
I've had a play with some USB microcontrollers which emulate various devices and can mimic other devices through their PID etc.
31-07-2014 9:13 PM
31-07-2014 9:26 PM
I.e. whether a USB keyboard could receive data sent by another USB keyboard on the same machine. I suspect not although there may be some interaction so things like caps lock etc are synchronised. If it could receive keypresses then keylogging is an obvious potential issue.
Potential to drop malicious software on the machine ? Possible but quite difficult as it would have to act as both a USB memory stick and a HID device for this to work.
Possible via keypresses to hit Win+R then CMD, Enter, copy con malicious.bat etc etc. A small batch file could be planted in the startup folder in seconds.
I think maybe the biggest danger would be from a USB stick which has malicious intents during the first 10 seconds of power up. It could drop a rootkit onto a PC on bootup if left in the machine. It could then revert back to a normal USB memory device so virtually undetectable. You could have some kind of random counter built in which for 99% of the time causes the memory stick to behave but that one time you leave it in and it turns on you .........
31-07-2014 9:52 PM
Nor would a PC necessarily try to boot first from the USB stick.
31-07-2014 10:27 PM
It reminds me of the time my stepson got my password - apparently it just appeared on his screen. Obviously I changed it but one day when he was at school, I noticed that things I had typed out in the workshop had appeared in a notepad that was open on his machine. We were both using wireless keyboards on the same frequency and the cabling between the workshop and house had acted as an aerial and the receiver on his machine could pick up what I was typing out in the workshop !
01-08-2014 1:01 AM
Quote from: rongtw Just been reading this http://www.techspot.com/news/57591-researchers-uncover-fundamental-usb-security-flaw-no-fix-in-sight...;
Actually that article implies that you you should never connect anything that uses firmware.
01-08-2014 6:26 AM
Perhaps someone will make a magic usb stick that can do something useful like be capable of flashing a 582n (one with a usb port, obviously) to OpenWRT.
01-08-2014 8:20 AM
http://www.dailymail.co.uk/sciencetech/article-2711802/Is-USB-drive-risk-Invisible-fundamental-flaw-...
01-08-2014 11:45 AM
01-08-2014 12:10 PM
I don't see how that is possible personally. Doesn't seem to be much evidence there, just words.
Sorry my mistake. I've just noticed the picture of a magnifying glass with a bit of code.
I guess it must be true then.
01-08-2014 7:08 PM
In reality anything can be made to look like a USB drive. Digital cameras look like USB drives to a computer when clearly they are not. Mobile dongles have a 'CD Drive' with embedded firmware. Even an USB enabled Arduino can be made to behave as a memory stick. But all of these assume there are the correct drivers on the target machine - the major headache with using any USB device. As you said Alex, there was a magnifying glass with some very scarey looking psuedo code, so it must be important.
Anyway, for you tech heads, check out this article, The best way to disable Autorun, for protection from infected USB flash drives
http://blogs.computerworld.com/the_best_way_to_disable_autorun_to_be_protected_from_infected_usb_fla...
01-08-2014 8:35 PM
The various standards are listed here: http://www.usb.org/developers/docs/devclass_docs/
I saw there's a described standard for updating the firmware of a usb device, but none of my usb devices implement that standard. I did update the firmware for a usb hard disk enclosure a long time ago, it was done in a non-standard vendor specific way that will only work on devices using that particular manufacturer's chip.
