Chromecast, US Netflix and Plusnet Router
- Chromecast, US Netflix and Plusnet Router
17-02-2014 3:29 PM
So I've made it my mission this morning to get this all working and I'm currently watching Season 4 of White Collar via the Chromecast on the TV using US Netflix. Thought I'd write a quick how-to using the Technicolor TG582n FTTC router (Plusnet standard issue) and the Unlocator Smart DNS Service (you will need to be signed up... It's free at the moment as it's in beta).
I've found the problem with the Chromecast is that the DNS settings are hard-wired to Google's DNS 8.8.8.8 and 8.8.4.4. So it's no good just overwriting the router DNS settings to use Unlocator or any other Smart DNS Service as the Chromecast will just go and do it's own thing anyway. So I added some static routes for the two Google DNS IP's and it's done the trick!
Few instructions:
1. tenet to dsldevice.lan (192.168.1.254)
2. login using admin and the router password
3. flush the plusnet dns servers
dns server route flush
4. add unlocator's smart dns servers
dns server route add dns=185.37.37.37 metric=10 intf=Internet
dns server route add dns=185.37.37.185 metric=10 intf=Internet
5. add static routes for google dns servers
ip rtadd dst=8.8.8.8/32 gateway=192.168.1.254
ip rtadd dst=8.8.4.4/32 gateway=192.168.1.254
6. save!
saveall
Hope it helps someone
Re: Chromecast, US Netflix and Plusnet Router
17-02-2014 5:50 PM
17-02-2014 11:48 PM
dick:quote
18-02-2014 9:52 AM
18-02-2014 4:23 PM
18-02-2014 4:51 PM
18-02-2014 4:54 PM
Netflix UK has different content to Netflix USA because of copy right laws.
That's what makes me suspect some law somewhere exists to stop people doing it!
I do hope I am wrong though.
19-02-2014 9:52 AM
As I've said I pay for UnoDns so I can stream to TV via laptop. Could possibly use Hola instead.
Possibly it's bending copyright rules but one pays monthly to Netflix and US content is superior - even people in Canada do it
I think if it was piracy action would have already been taken.
22-02-2014 2:01 PM
Quote from: Devonian But a multi region DVD is marketed as such.
The only way arcane licensing deals can be made a thing of the past is to make them useless. The only reason the content is different between is the greed of whoever has the rights.
Its like piracy, there'll always be people who pirate content regardless, but for most is its easy to assess at a reasonable cost then why bother pirating? Same boat with Sky's recent crying on the BBC about how people can get £100+ a month TV subscriptions for under a tenner. Other than corporate greed there is no reason for it to be so expensive, and if it was reasonable cost then there would be no reason to spend X on receivers and messing around with softcams.
03-05-2014 12:01 PM
also found these free DNS servers that are currently working:
pri 214.5.182.127
sec 162.243.65.31
Thank, Jazz Man.
11-11-2014 12:37 AM
