cgi form email script not working (404)
- Everything else
- cgi form email script not working (404)
28-09-2014 11:58 AM
However, as of recently (this last week?) it is now generating a 404 when users click "Submit".
Is this an oversight at Plusnet's end, or should I be making changes our site accordingly?
Thanks,
Re: cgi form email script not working (404)
28-09-2014 2:56 PM
Hopefully someone on here can check it to see what's happened. I imagine lots of others use it also but don't realise it's currently a broken address.
28-09-2014 10:57 PM
Edit: Internal problem raised (ref: 82966)
03-10-2014 4:31 PM
03-10-2014 4:52 PM
If you were following the news around the time they stopped working, you can probably figure out what the reason was
Some work will be required on our part before we're able to restore access so it might be an idea to look around for alternatives in the interim.
03-10-2014 5:48 PM
06-10-2014 11:44 AM
Quote from: cyberdynesystems ... any chance I can be given cgi access with my web space?
You should be able to log in here. ccgi.username.plus.com as the username (replacing 'username' with your actual username of course) and your usual password. You'll need to set a master FTP password using the relevant fields to the lower-left of the FTP Manager application.
06-10-2014 12:41 PM
06-10-2014 2:30 PM
07-10-2014 7:22 PM
08-10-2014 11:53 AM
08-10-2014 2:07 PM
However, https access to ccgi.username.plus.com doesn't seem to work, despite the fact that it looks like various secure links are set up by default. I rather assumed that simply https://ccgi.username.plus.com/ etc. would suffice. Is there something else I need to do please?
08-10-2014 4:45 PM
08-10-2014 5:52 PM
10-10-2014 3:09 PM
I have tried logging in with ccgi.username.plus.com (replacing username with my real username) but it won't let me log in? Am I doing something wrong?
- Everything else
