ASUS DSL-N66U / DSL-AC68U - Information please
- ASUS DSL-N66U / DSL-AC68U - Information please
16-09-2014 1:00 PM
If you can let me know whats via the web GUI and also if any more info is available via the CLI that would be great.
TIA
Re: ASUS DSL-N66U / DSL-AC68U - Information please
19-09-2014 12:35 PM
Does anyone have any info of what type of line stats you can get please
TIA
19-09-2014 12:57 PM
19-09-2014 12:58 PM
EDIT: I'm wrong. The DSL's are of course, modem routers.
19-09-2014 1:11 PM
The DSL-N66U is a combined adsl/vdsl modem router. I believe it has a Media Tek DSL chipset which Im not familiar with, and I wanted to know how much info they give the EU.
Its the RT-N66U which is router only and still needs the BT Openreach modem to work on FTTC.
ETA
Just seen you twigged yourself at the same time I was posting.
19-09-2014 1:39 PM
19-09-2014 2:15 PM
Im not familiar with its GUI (read I know nada), but I guess what Im looking for may perhaps be found under something like system log -> DSL log -> Link status
.. and if it contains anything more comprehensive than this... which is more aimed at adsl rather than vdsl diagnostics
19-09-2014 2:47 PM
19-09-2014 2:58 PM
2011-01-01 00:04:02 System log daemon exiting.
2010-12-31 16:00:55 syslogd started: BusyBox v1.00 (2014.09.01-10:16+0000)
2010-12-31 16:00:56 kernel: RTS debug message OFF!
2010-12-31 16:00:56 kernel: log cicmd 0 (wan dmt2 set largeD 2 )
2010-12-31 16:00:56 kernel: usbcore: registered new interface driver usbfs
2010-12-31 16:00:56 kernel: usbcore: registered new interface driver hub
2010-12-31 16:00:56 kernel: usbcore: registered new device driver usb
2010-12-31 16:00:57 kernel: SCSI subsystem initialized
2010-12-31 16:00:58 WEB: WEB user <admin> login
2010-12-31 16:01:01 WEB: Configuration changed: LanguageSwitch_Entry
2010-12-31 16:01:02 kernel: Initializing USB Mass Storage driver...
2010-12-31 16:01:02 kernel: usbcore: registered new interface driver usb-storage
2010-12-31 16:01:02 kernel: USB Mass Storage support registered.
2010-12-31 16:01:04 kernel: ufsd:: trace mask set to 0000000f
2010-12-31 16:01:04 kernel: ufsd: driver (UFSD_HEAD lke_8.9.0_r209178_b9, LBD=ON, acl, ioctl, sd, wb, tr) loaded at c02ac000
2010-12-31 16:01:04 kernel: NTFS support included
2010-12-31 16:01:04 kernel: Big endian platform
2010-12-31 16:01:04 kernel: optimized: speed
2010-12-31 16:01:04 kernel: Build_for__ASUS_PRODUCTS_001_k2.6.22.15_2012-12-24_lke_8.9.0_r209178_b9
2010-12-31 16:01:05 kernel: PCI: Enabling device 0000:02:03.3 (0000 -> 0002)
2010-12-31 16:01:05 kernel: ehci_hcd 0000:02:03.3: EHCI Host Controller
2010-12-31 16:01:05 kernel: ehci_hcd 0000:02:03.3: new USB bus registered, assigned bus number 1
2010-12-31 16:01:05 kernel: ehci_hcd 0000:02:03.3: irq 21, io mem 0x1fba1000
2010-12-31 16:01:05 kernel: ehci_hcd 0000:02:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
2010-12-31 16:01:05 kernel: usb usb1: configuration #1 chosen from 1 choice
2010-12-31 16:01:05 kernel: hub 1-0:1.0: USB hub found
2010-12-31 16:01:05 kernel: hub 1-0:1.0: 2 ports detected
2010-12-31 16:01:05 kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
2010-12-31 16:01:05 kernel: PCI: Enabling device 0000:02:03.0 (0000 -> 0002)
2010-12-31 16:01:05 kernel: PCI: Setting latency timer of device 0000:02:03.0 to 64
2010-12-31 16:01:05 kernel: ohci_hcd 0000:02:03.0: OHCI Host Controller
2010-12-31 16:01:05 kernel: ohci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 2
2010-12-31 16:01:05 kernel: ohci_hcd 0000:02:03.0: irq 24, io mem 0x1fba0000
2010-12-31 16:01:06 kernel: usb usb2: configuration #1 chosen from 1 choice
2010-12-31 16:01:06 kernel: hub 2-0:1.0: USB hub found
2010-12-31 16:01:06 kernel: hub 2-0:1.0: 2 ports detected
2010-12-31 16:01:06 kernel: usbcore: registered new interface driver usblp
2010-12-31 16:01:06 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
2010-12-31 16:01:10 kernel: br1: topology change detected, propagating
2010-12-31 16:01:10 kernel: br1: port 1(eth0.12) entering forwarding state
2010-12-31 16:01:46 WEB: Configuration changed: SysInfo_Entry
2010-12-31 16:01:46 kernel:
2010-12-31 16:01:46 kernel: wlan_write---goto fopen!!WPSActiveStatus = NULL
2010-12-31 16:01:46 kernel: WPSOOBActive = NULL
2010-12-31 16:01:46 kernel: ReCounterActive = NULL
2010-12-31 16:01:46 kernel: WPSGenPinCode = NULL
2010-12-31 16:01:46 kernel: Net device ra00_0 going down....
2010-12-31 16:01:46 kernel: rlk_inic_mbss_close --->
2010-12-31 16:01:47 kernel: rlk_inic_mbss_close <---
2010-12-31 16:01:47 kernel: iNIC Closed
2010-12-31 16:01:47 kernel: br0: port 2(ra00_0) entering disabled state
2010-12-31 16:01:47 kernel: device ra00_0 left promiscuous mode
2010-12-31 16:01:48 kernel: Net device ra01_0 going down....
2010-12-31 16:01:48 kernel: rlk_inic_mbss_close --->
2010-12-31 16:01:48 kernel: setup MBSS[0] success
2010-12-31 16:01:48 kernel: all interfaces closed.
2010-12-31 16:01:48 kernel: rlk_inic_mbss_close <---
2010-12-31 16:01:48 kernel: iNIC Closed
2010-12-31 16:01:48 kernel: Delete HeartBeatTimer ....
2010-12-31 16:01:48 kernel: br0: port 3(ra01_0) entering disabled state
2010-12-31 16:01:48 kernel: device ra01_0 left promiscuous mode
2010-12-31 16:01:49 kernel: iNIC Open ra00_0
2010-12-31 16:01:49 kernel: Op mode = 1
2010-12-31 16:01:49 kernel: Read profile[0]
2010-12-31 16:01:49 kernel: BssidNum=4
2010-12-31 16:01:49 kernel: Read profile[1]
2010-12-31 16:01:49 kernel: Wait for boot done...
2010-12-31 16:01:49 kernel: RACFG_CMD_BOOT_NOTIFY
2010-12-31 16:01:49 kernel: Open file: /etc/Wireless/RT6856/iNIC.bin
2010-12-31 16:01:50 kernel: RACFG_CMD_BOOT_INITCFG(1)
2010-12-31 16:02:09 kernel: RACFG_CMD_BOOT_UPLOAD(0)
2010-12-31 16:02:09 kernel: RACFG_CMD_BOOT_UPLOAD(1)
2010-12-31 16:02:09 kernel: RACFG_CMD_BOOT_UPLOAD(2)
2010-12-31 16:02:09 kernel: CRC:01 08 14 18 58 45 b1 4f 22 32 2e 35 2e 33 2e 34 22 00 00 00 32 30 31 32 30 34 31 30 00 00 00 00 00 00 00 00 24 8e 00 00
2010-12-31 16:02:09 kernel: RACFG_CMD_BOOT_STARTUP
2010-12-31 16:02:09 kernel: RACFG_CMD_BOOT_NOTIFY
2010-12-31 16:02:09 kernel: Open file: /etc/Wireless/RT6856/iNIC_ap.bin
2010-12-31 16:02:09 kernel: Open file: /etc/Wireless/RT6856/iNIC_ap.dat
2010-12-31 16:02:09 kernel: Open file: /etc/Wireless/RT6856/iNIC_ap1.dat
2010-12-31 16:02:44 WEB: Configuration changed: SysInfo_Entry
2010-12-31 16:02:44 kernel:
2010-12-31 16:02:44 kernel: WPSActiveStatus = NULL
2010-12-31 16:02:44 kernel: WPSOOBActive = NULL
2010-12-31 16:02:44 kernel: ReCounterActive = NULL
2010-12-31 16:02:44 kernel: WPSGenPinCode = NULL
2010-12-31 16:02:44 kernel: Net device ra00_0 going down....
2010-12-31 16:02:44 kernel: rlk_inic_mbss_close --->
2010-12-31 16:02:44 kernel: rlk_inic_mbss_close <---
2010-12-31 16:02:45 kernel: iNIC Closed
2010-12-31 16:02:45 kernel: br0: port 2(ra00_0) entering disabled state
2010-12-31 16:02:45 kernel: device ra00_0 left promiscuous mode
2010-12-31 16:02:45 kernel: Net device ra01_0 going down....
2010-12-31 16:02:45 kernel: rlk_inic_mbss_close --->
2010-12-31 16:02:46 kernel: setup MBSS[0] success
2010-12-31 16:02:46 kernel: all interfaces closed.
2010-12-31 16:02:46 kernel: rlk_inic_mbss_close <---
2010-12-31 16:02:46 kernel: iNIC Closed
2010-12-31 16:02:46 kernel: Delete HeartBeatTimer ....
2010-12-31 16:02:46 kernel: br0: port 3(ra01_0) entering disabled state
2010-12-31 16:02:46 kernel: device ra01_0 left promiscuous mode
2010-12-31 16:02:46 kernel: iNIC Open ra00_0
2010-12-31 16:02:46 kernel: Op mode = 1
2010-12-31 16:02:46 kernel: Read profile[0]
2010-12-31 16:02:46 kernel: BssidNum=4
2010-12-31 16:02:46 kernel: Read profile[1]
2010-12-31 16:02:46 kernel: Wait for boot done...
2010-12-31 16:02:48 kernel: RACFG_CMD_BOOT_NOTIFY
2010-12-31 16:02:48 kernel: Open file: /etc/Wireless/RT6856/iNIC.bin
2010-12-31 16:02:49 kernel: RACFG_CMD_BOOT_INITCFG(2)
2010-12-31 16:03:09 kernel: RACFG_CMD_BOOT_UPLOAD(0)
2010-12-31 16:03:09 kernel: RACFG_CMD_BOOT_UPLOAD(1)
2010-12-31 16:03:09 kernel: RACFG_CMD_BOOT_UPLOAD(2)
2010-12-31 16:03:09 kernel: CRC:01 08 14 18 58 45 b1 4f 22 32 2e 35 2e 33 2e 34 22 00 00 00 32 30 31 32 30 34 31 30 00 00 00 00 00 00 00 00 24 8e 00 00
2010-12-31 16:03:09 kernel: RACFG_CMD_BOOT_STARTUP
2010-12-31 16:03:09 kernel: RACFG_CMD_BOOT_NOTIFY
2010-12-31 16:03:09 kernel: Open file: /etc/Wireless/RT6856/iNIC_ap.bin
2010-12-31 16:03:09 kernel: Open file: /etc/Wireless/RT6856/iNIC_ap.dat
2010-12-31 16:03:09 kernel: Open file: /etc/Wireless/RT6856/iNIC_ap1.dat
2010-12-31 16:03:09 WEB: Configuration changed: WLan_Entry
2010-12-31 16:03:21 WEB: Configuration changed: SysInfo_Entry
2010-12-31 16:03:21 kernel:
2010-12-31 16:03:21 kernel: wlan_write---goto fopen!!WPSActiveStatus = NULL
2010-12-31 16:03:21 kernel: WPSOOBActive = NULL
2010-12-31 16:03:21 kernel: ReCounterActive = NULL
2010-12-31 16:03:21 kernel: WPSGenPinCode = NULL
2010-12-31 16:03:21 kernel: Net device ra00_0 going down....
2010-12-31 16:03:21 kernel: rlk_inic_mbss_close --->
2010-12-31 16:03:21 kernel: rlk_inic_mbss_close <---
2010-12-31 16:03:21 kernel: iNIC Closed
2010-12-31 16:03:21 kernel: br0: port 2(ra00_0) entering disabled state
2010-12-31 16:03:21 kernel: device ra00_0 left promiscuous mode
2010-12-31 16:03:22 kernel: Net device ra01_0 going down....
2010-12-31 16:03:22 kernel: rlk_inic_mbss_close --->
2010-12-31 16:03:22 kernel: setup MBSS[0] success
2010-12-31 16:03:22 kernel: all interfaces closed.
2010-12-31 16:03:22 kernel: rlk_inic_mbss_close <---
2010-12-31 16:03:23 kernel: iNIC Closed
2010-12-31 16:03:23 kernel: Delete HeartBeatTimer ....
2010-12-31 16:03:23 kernel: br0: port 3(ra01_0) entering disabled state
2010-12-31 16:03:23 kernel: device ra01_0 left promiscuous mode
2010-12-31 16:03:23 kernel: iNIC Open ra00_0
2010-12-31 16:03:23 kernel: Op mode = 1
2010-12-31 16:03:23 kernel: Read profile[0]
2010-12-31 16:03:23 kernel: BssidNum=4
2010-12-31 16:03:23 kernel: Read profile[1]
2010-12-31 16:03:23 kernel: Wait for boot done...
2010-12-31 16:04:03 kernel: RACFG_CMD_BOOT_NOTIFY
2010-12-31 16:04:03 kernel: Open file: /etc/Wireless/RT6856/iNIC.bin
2010-12-31 16:04:03 kernel: RACFG_CMD_BOOT_INITCFG(3)
2010-12-31 16:04:03 kernel: RACFG_CMD_BOOT_UPLOAD(0)
2010-12-31 16:04:03 kernel: RACFG_CMD_BOOT_UPLOAD(1)
2010-12-31 16:04:03 kernel: RACFG_CMD_BOOT_UPLOAD(2)
2010-12-31 16:04:03 kernel: CRC:01 08 14 18 58 45 b1 4f 22 32 2e 35 2e 33 2e 34 22 00 00 00 32 30 31 32 30 34 31 30 00 00 00 00 00 00 00 00 24 8e 00 00
2010-12-31 16:04:03 kernel: RACFG_CMD_BOOT_STARTUP
2010-12-31 16:04:03 WEB: Configuration changed: WLan_Entry
2010-12-31 16:04:19 dnsmasq[3909]: started, version 2.52 cachesize 150
2010-12-31 16:04:19 dnsmasq[3909]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2010-12-31 16:04:19 dnsmasq[3909]: reading /etc/resolv.conf
2010-12-31 16:04:19 dnsmasq[3909]: ignoring nameserver ::1 - local interface
2010-12-31 16:04:19 dnsmasq[3909]: ignoring nameserver 127.0.0.1 - local interface
2010-12-31 16:04:19 dnsmasq[3909]: read /etc/hosts - 4 addresses
2010-12-31 16:04:20 Samba Server: smb daemon is stoped
2010-12-31 16:04:20 WEB: Configuration changed: Lan
2010-12-31 16:04:20 WEB: Configuration changed: DhcpRelay_Entry
2010-12-31 16:04:22 WEB: Configuration changed: Dhcpd_Common
2010-12-31 16:04:22 WEB: Configuration changed: Dproxy_Entry
2010-12-31 16:04:23 Samba Server: daemon is started
2010-12-31 16:04:58 nmbd[4065]: [2010/12/31 16:04:58, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
2010-12-31 16:04:58 nmbd[4065]: Samba name server DSL-N66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
2010-12-31 16:09:11 kernel: tc3262_ptm_close
2010-12-31 16:09:12 kernel: nas8: starting interface.
2010-12-31 16:09:13 syslog: Initialize LCP.
2010-12-31 16:09:15 syslog: Plugin libpppoe.so loaded.
2010-12-31 16:09:15 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
2010-12-31 16:09:15 syslog: pppd 2.4.5 started by admin, uid 0
2010-12-31 16:09:15 syslog: LCP is allowed to come up.
2010-12-31 16:09:15 WEB: Configuration changed: Route
2010-12-31 16:09:15 kernel: log cicmd 7 (wan vdsl2 set sra on )
2010-12-31 16:09:15 kernel: US bitswap on,DS bitswap on
2010-12-31 16:09:15 kernel: log cicmd 8 (wan vdsl2 set bs_tx on )
2010-12-31 16:09:15 kernel: log cicmd 9 (wan vdsl2 set bs on )
2010-12-31 16:09:15 kernel: Set SNRM OFFSET = 0.0 db
2010-12-31 16:09:15 kernel: log cicmd 10 (wan vdsl2 set target_snrm 32767 )
2010-12-31 16:09:15 kernel: PROFILE30A_MULTI_MODE
2010-12-31 16:09:15 kernel: log cicmd 11 (wan vdsl set tx_gain_off 32767 )
2010-12-31 16:09:15 kernel: log cicmd 12 (wan vdsl set agc 65535 65535 65535 65535 )
2010-12-31 16:09:15 kernel: log cicmd 13 (wan vdsl set upbo 255 )
2010-12-31 16:09:15 kernel: ANNEXAIJLM
2010-12-31 16:09:15 WEB: Configuration changed: Adsl_Entry
2010-12-31 16:09:22 kernel: nas8: no IPv6 routers present
2010-12-31 16:09:23 kernel: nas8_0: no IPv6 routers present
2010-12-31 16:11:21 System log daemon exiting.
2010-12-31 16:11:23 syslogd started: BusyBox v1.00 (2014.09.01-10:16+0000)
2010-12-31 16:11:24 Samba Server: daemon is started
2011-01-01 00:16:06 WEB: Configuration changed: VirServer_PVC_Entry
2011-01-01 00:17:08 nmbd[7174]: [2011/01/01 00:17:08, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
2011-01-01 00:17:08 nmbd[7174]: Samba name server DSL-N66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
2011-01-01 00:17:48 WEB: Configuration changed: VirServer_PVC_Entry
2011-01-01 00:24:26 WEB: Configuration changed: VirServer_PVC_Entry
2011-01-01 00:26:20 WEB: Configuration changed: VirServer_PVC_Entry
2011-01-01 00:26:51 WEB: Configuration changed: VirServer_PVC_Entry
2011-01-01 00:29:51 FTP Server: daemon is stoped
2011-01-01 00:30:23 FTP Server: daemon is stoped
2011-01-01 00:33:42 WEB: Configuration changed: ipv6rd_Entry
2011-01-01 00:01:03 syslogd started: BusyBox v1.00 (2014.09.01-10:16+0000)
2011-01-01 00:01:03 kernel: RTS debug message OFF!
2011-01-01 00:01:03 kernel: log cicmd 0 (wan dmt2 set largeD 2 )
2011-01-01 00:01:04 kernel: usbcore: registered new interface driver usbfs
2011-01-01 00:01:04 kernel: usbcore: registered new interface driver hub
2011-01-01 00:01:04 kernel: usbcore: registered new device driver usb
2011-01-01 00:01:04 kernel: SCSI subsystem initialized
2011-01-01 00:01:05 kernel: Initializing USB Mass Storage driver...
2011-01-01 00:01:05 kernel: usbcore: registered new interface driver usb-storage
2011-01-01 00:01:05 kernel: USB Mass Storage support registered.
2011-01-01 00:01:07 kernel: ufsd:: trace mask set to 0000000f
2011-01-01 00:01:07 kernel: ufsd: driver (UFSD_HEAD lke_8.9.0_r209178_b9, LBD=ON, acl, ioctl, sd, wb, tr) loaded at c02ac000
2011-01-01 00:01:07 kernel: NTFS support included
2011-01-01 00:01:07 kernel: Big endian platform
2011-01-01 00:01:07 kernel: optimized: speed
2011-01-01 00:01:07 kernel: Build_for__ASUS_PRODUCTS_001_k2.6.22.15_2012-12-24_lke_8.9.0_r209178_b9
2011-01-01 00:01:08 kernel: PCI: Enabling device 0000:02:03.3 (0000 -> 0002)
2011-01-01 00:01:08 kernel: ehci_hcd 0000:02:03.3: EHCI Host Controller
2011-01-01 00:01:08 kernel: ehci_hcd 0000:02:03.3: new USB bus registered, assigned bus number 1
2011-01-01 00:01:08 kernel: ehci_hcd 0000:02:03.3: irq 21, io mem 0x1fba1000
2011-01-01 00:01:08 kernel: ehci_hcd 0000:02:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
2011-01-01 00:01:08 kernel: usb usb1: configuration #1 chosen from 1 choice
2011-01-01 00:01:08 kernel: hub 1-0:1.0: USB hub found
2011-01-01 00:01:08 kernel: hub 1-0:1.0: 2 ports detected
2011-01-01 00:01:08 kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
2011-01-01 00:01:08 kernel: PCI: Enabling device 0000:02:03.0 (0000 -> 0002)
2011-01-01 00:01:08 kernel: PCI: Setting latency timer of device 0000:02:03.0 to 64
2011-01-01 00:01:08 kernel: ohci_hcd 0000:02:03.0: OHCI Host Controller
2011-01-01 00:01:08 kernel: ohci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 2
2011-01-01 00:01:08 kernel: ohci_hcd 0000:02:03.0: irq 24, io mem 0x1fba0000
2011-01-01 00:01:08 kernel: usb usb2: configuration #1 chosen from 1 choice
2011-01-01 00:01:08 kernel: hub 2-0:1.0: USB hub found
2011-01-01 00:01:08 kernel: hub 2-0:1.0: 2 ports detected
2011-01-01 00:01:08 WAN Connection: Fail to connect with some issues.
2011-01-01 00:01:08 kernel: usbcore: registered new interface driver usblp
2011-01-01 00:01:08 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
2011-01-01 00:01:11 kernel: set cicmd 3
2011-01-01 00:01:11 kernel: 1: wan vdsl set tx_gain_off 32767
2011-01-01 00:01:11 kernel: new_tx_gain_offset = 32767
2011-01-01 00:01:11 kernel: 2: wan vdsl set agc 65535 65535 65535 65535
2011-01-01 00:01:11 kernel: new agc_ref = 65535,65535,65535,65535
2011-01-01 00:01:11 kernel: 3: wan vdsl set upbo 255
2011-01-01 00:01:11 kernel: cur upbo =1
2011-01-01 00:01:11 kernel: usage: wan vdsl2 set upbo [on|off]
2011-01-01 00:01:17 kernel: br1: topology change detected, propagating
2011-01-01 00:01:17 kernel: br1: port 1(eth0.12) entering forwarding state
2011-01-01 00:01:33 kernel: tc3262_ptm_close
2011-01-01 00:01:33 syslog: error receiving pppoe packet: Network is down
2011-01-01 00:01:36 kernel: tc3262_ptm_close
2011-01-01 00:01:37 kernel: nas8: starting interface.
2011-01-01 00:01:37 syslog: Initialize LCP.
2011-01-01 00:01:37 syslog: Plugin libpppoe.so loaded.
2011-01-01 00:01:37 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
2011-01-01 00:01:37 syslog: pppd 2.4.5 started by admin, uid 0
2011-01-01 00:01:37 syslog: LCP is allowed to come up.
2011-01-01 00:01:37 kernel: Link State: DSL link up.
2011-01-01 00:01:38 dnsmasq[2761]: started, version 2.52 cachesize 150
2011-01-01 00:01:38 dnsmasq[2761]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2011-01-01 00:01:38 dnsmasq[2761]: reading /etc/resolv.conf
2011-01-01 00:01:38 dnsmasq[2761]: ignoring nameserver ::1 - local interface
2011-01-01 00:01:38 dnsmasq[2761]: ignoring nameserver 127.0.0.1 - local interface
2011-01-01 00:01:38 dnsmasq[2761]: read /etc/hosts - 4 addresses
2011-01-01 00:01:38 kernel: tc3262_ptm_close
2011-01-01 00:01:38 syslog: error receiving pppoe packet: Network is down
2011-01-01 00:01:41 kernel: nas8: starting interface.
2011-01-01 00:01:42 syslog: Initialize LCP.
2011-01-01 00:01:44 syslog: Plugin libpppoe.so loaded.
2011-01-01 00:01:44 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
2011-01-01 00:01:44 syslog: pppd 2.4.5 started by admin, uid 0
2011-01-01 00:01:44 syslog: LCP is allowed to come up.
2011-01-01 00:01:51 kernel: nas8: no IPv6 routers present
2011-01-01 00:01:52 kernel: nas8_0: no IPv6 routers present
2011-01-01 00:01:57 syslog: PADS: Service-Name: ''
2011-01-01 00:01:57 syslog: PPP session is 2463
2011-01-01 00:01:57 syslog: Connected to 00:30:88:00:00:02 via interface nas8_0
2011-01-01 00:01:57 syslog: using channel 1
2011-01-01 00:01:57 syslog: Using interface ppp80
2011-01-01 00:01:57 syslog: Connect: ppp80 <--> nas8_0
2011-01-01 00:02:00 syslog: CHAP authentication succeeded
2011-01-01 00:02:00 syslog: CHAP authentication success
2011-01-01 00:02:00 syslog: peer from calling number 00:30:88:00:00:02 authorized
2011-01-01 00:02:00 syslog: local IP address ******* (edit)
2011-01-01 00:02:00 syslog: remote IP address ******* (edit)
2011-01-01 00:02:00 syslog: primary DNS address ******* (edit)
2011-01-01 00:02:00 syslog: secondary DNS address 212.15
2011-01-01 00:02:01 kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2011-01-01 00:02:01 kernel: Link State: PVC_8_0 logistic interface up.
2011-01-01 00:02:02 dnsmasq[3425]: started, version 2.52 cachesize 150
2011-01-01 00:02:02 dnsmasq[3425]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2011-01-01 00:02:02 dnsmasq[3425]: using nameserver 212.159.6.10#53(via ppp80)
2011-01-01 00:02:02 dnsmasq[3425]: using nameserver 212.159.6.9#53(via ppp80)
2011-01-01 00:02:02 dnsmasq[3425]: reading /etc/resolv.conf
2011-01-01 00:02:02 dnsmasq[3425]: ignoring nameserver ::1 - local interface (edit)
2011-01-01 00:02:02 dnsmasq[3425]: ignoring nameserver 127.0.0.1 - local interface
2011-01-01 00:02:02 dnsmasq[3425]: using nameserver 212.159#53(via ppp80) (edit)
2011-01-01 00:02:02 dnsmasq[3425]: read /etc/hosts - 4 addresses
2014-09-19 12:40:38 WAN Connection: WAN was restored.
2014-09-19 12:40:38 start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2014-09-19 12:44:07 WEB: WEB user <admin> login
2014-09-19 13:14:08 WEB: WEB user <admin> login
2014-09-19 14:07:37 WEB: WEB user <admin> login
20-09-2014 12:08 PM
20-09-2014 3:23 PM
20-09-2014 5:50 PM
20-09-2014 9:50 PM
@redbull2k14 why did u tick VDSL Profile under 30a multi mode on your screenshot above as Plusnet FTTC is on the 17a multi mode at the moment as BTw FTTC doesnt have profile 30a at present?
20-09-2014 9:56 PM
21-09-2014 3:02 AM
