Which is better - BT Smart Hub 2 or Plusnet Hub 1 ? For the man Baldrick1
FIXEDTopic Options
- Which is better - BT Smart Hub 2 or Plusnet Hub 1 ...
- « Previous
- Next »
Re: Which is better - BT Smart Hub 2 or Plusnet Hub 1 ? For the man Baldrick1
15-06-2022 9:01 AM
Thanks Bob, I'll give it a go.
Message 31 of 36
(2,250 Views)
16-06-2022 7:02 PM
Hi Bob,
I disabled 5 GHz and tried adding my smart plugs. No joy. Reverted back to my old router and they all loaded first time. Thanks anyway.
Message 32 of 36
(2,213 Views)
16-06-2022 7:05 PM
Hi Lauren, I disabled 5GHz and tried adding my smart plugs. No joy. Reverted back to the old router and they loaded straight away. If the Hub 2 is supposed to be an improvement something needs to be done for 2.4GHz devices.
Message 33 of 36
(2,212 Views)
16-06-2022 7:30 PM
Thanks for the update @ncc562, I'm sorry that it didn't work though pleased you've been able to connect the old router back up.
Message 34 of 36
(2,203 Views)
16-06-2022 8:45 PM
Did you try the different wireless modes?
Other suggestions: -
1. Try changing the Wi-Fi name/password on the Hub Two so matches those you were using on the older router.
2. Fully reset the smart plugs before trying to re-pair them with the Hub Two.
FWIW, I have 2.4GHz only smartplugs on my network and they work fine with my Hub Two.
Message 35 of 36
(2,180 Views)
16-06-2022 9:12 PM
Ok Bob, I'll give it a go this weekend.
Message 36 of 36
(2,169 Views)
- « Previous
- Next »
