Friday 12th February 2016Login | Register
Pages: 1 ... 3 4 [5] 6
PS3 Nat type HELP
« Reply #64 on 10/11/2011, 21:32 »
When i go to the telnet bit and it asks for the username i put in admin, then i have tried leaving the password blank and it just closes.  I have tried the serial number of the router beginning CP but it says invalid username/password.  I have tried administrator too instead of admin but get the same results.
Any help with this?  How could i find the password if it is neither of them?
Edit:- sorted it - administrator should be Administrator lol
« Last Edit: 10/11/2011, 21:38 by johnnybebad2000 »
Logged
« Reply #65 on 10/11/2011, 21:43 »
Wowzers, NAT Type is now open after following that guide!!
Thank You So SO much, ive been fighting with this issue for so long.
Right, now to play some MW3, normally on a wired connection but going to try wireless tonight since i have moved the router to the main phone socket.  I just hope its stable!!
Logged
« Reply #66 on 10/11/2011, 22:22 »
@Ashraf
Mate one of the other members has this problem, he goes online (NAT = STRICT), close the game (go back to the ps3 menu) then reload the game, NAT = Open.
At a guess its uPNP making a mess of things rather than doing its wonderfully brilliant Opening on request :p
Regards
me @ - last.fm
Plusnet Acc #1 since 30/01/2003 -- PN Premier Option 1 (512K), PN Unlimited (3mbit), PN Extra Fibre (80mbit - 60 actual),PN Unlimited Fibre,
Plusnet Acc #2 since 18/11/2009 -- PN Premier (4mbit), PN Extra Fibre Pro (80mbit - 60 actual), PN Unlimited Fibre, - Closed ~08/08/2014 due to finances. Want this back!
Logged
  • MrN
  • View Profile
« Reply #67 on 10/11/2011, 22:24 »
Well, NAT type open yesterday on MW3 and 13:30 (yesterday) the big switch over to "PRO" and then as if by magic NAT type now strict and a downgrade in overall line speed and DL speed
"Phone exchange:SCARBOROUGHEstimated line speed:5Mb (This may vary between 4.5Mb and 8Mb) - Checked on 2011-11-09 13:38:26Current line speed: 7.15 Mb"
Dl speed now running at 4.8 as per "My Broadband" test. Last complaint is februarury and sync rates were 10+ now they are less than 9+, this broadband just keeps getting slower and slower and, then cost is reduced overall then add the "bolt on" to improve, what improvement???Angry
PS3 was static IP yesterday and UPNP is on.
« Last Edit: 10/11/2011, 22:29 by MrN »
Logged
« Reply #68 on 10/11/2011, 22:29 »
MrN i suggest you start a new throad in "broadband and routers". post your router stats, its more than likely your using a phone extension, or something which is degrading your service.
Adding PRO does nothing other than remove traffic shaping done by PN it does NOT affect your sync speed (the only persons able to influence sync are BT and yourselves)
Open a thread with as much details as possible (and politely, you'll get more help this way) and await a response Smiley
Regards
me @ - last.fm
Logged
  • MrN
  • View Profile
« Reply #69 on 10/11/2011, 22:33 »
 Wink No extensions etc, no change in anything with phone line in over 18 months of use on PN. Just asking why NAT type should change after switching to PRO (for all additional gaming benefits). The other element is just the ususal rant about the degrading service. Sad
Logged
« Reply #70 on 11/11/2011, 00:40 »
its coincidental, nothing more i assure you.
Like i said before, if you feel your not getting what you "used to get" open a thread and see what digicare can do in the morning... JoJo is pretty good at getting people to pre-problem speeds.
Regards
me @ - last.fm
Logged
« Reply #71 on 11/11/2011, 03:19 »
Any smarty pants want to investigate on why when mw3 nat type open bf3 goes down when trying to play online and vise versa.
Logged
« Reply #72 on 11/11/2011, 09:06 »
Sorry for the many many posts but have been looking and searching and found this:
Guide to obtain OPEN NAT in PS3 Black Ops with Thomson TG782T Modem
Step 1- On your PC go to start click on run copy and paste this command. telnet 192.168.1.254 (press enter)
This will open a telnet session with your modem, you will then be asked for a Username and Password.
Username: admin (press enter)
Password: your modems password (usually blank by default) (press enter)
Step 2- copy and paste these 4 command lines one at a time pressing enter after each one is done.
:connection bind application=CONE(UDP) port=3074-3075
:connection bind application=CONE(UDP) port=3478-3479
:connection bind application=CONE(UDP) port=3658
:saveall
then close the telnet session
Step 3- Reboot your modem (just power off and back on) not always needed but is helpful to do after changes made.
Step 4- Open Call Of Duty Black Ops on PS3, go to multiplayer and enjoy your OPEN NAT gaming from now on =)
(edit) also i made a youtube video of this process in the link below to help assist people through this guide.
http://www.youtube.com/watch?v=G-gv5fAFzaY
Reference to how this fix was achieved- /forum-replies.cfm?t=1736568
I have done this and can confirm that it has opened my NAT, yay!
woop works a treat took a few attempts to get it to log in to telnet now have an open nat thankyou so much  Cheesy
Logged
« Reply #73 on 11/11/2011, 22:28 »
Hi everyone!
OK I've used the portforward guide to try and open the nat on my ps3 . Opened 3074 and 27000 , then tried 3074 and 27000 to 27050 . Changed the upnp settings backwards and forwards and turned router/ps3 on/off after each adjustment. Static IP appears fine, although it's the first time I'm doing any of this so I could be wrong. I do not own a pc so can't do the cmd solve that everyone else is doing. I'm about ready to cancel this whole subscription because I never had this problem with my previous ISP! Any help from someone more knowledgeable than me much appreciated Shocked
Logged
« Reply #74 on 12/11/2011, 00:46 »
Thats just rediculous, thats like saying You've bought a car, but you're going to take it back because you dont agree that the manufacturers rugs are cheap and abit tacky, when you could replace them cheaply and get a much better experience.
Im guessing that you own a mac instead of a PC then... ? all you need to do is say what you have, then we can help...
Opening the ports (all the ones listed in the thread) should be adequate and point them to the static IP of the PS3. you kno you should be opening ALL of the ports, not just trying one range then the next... right?
Regards
me @ - last.fm
Logged
« Reply #75 on 12/11/2011, 07:54 »
Hi Matt, Sorry was past my usual bedtime! Don't have a mac or pc or laptop. Ps3 is fine for me with gaming and basic browser. I did try the ports at the same time, but only the ones on portforward. Should I put the ones in your post 3074-3075, 3478-3479, 3658? Also what should my other settings be? If I disable upnp on ps3 I get nat 3 which seems bad. Should I allow it on the router? Should I turn off the firewall? Portforward.com doesn't explain! Also I have the TG585v8 if that helps. If you're able to help over the phone that would be a god send! My broadband was only activated yesterday and that's when the problems started, hence my below comment. I've been playing MW3 since Tuesday with no problem on my old settings/ISP. I feel like just sending the whole lot back to Plusnet at the minute. Was so frustrated and tired I ended up getting into bed in tears!
Logged
« Reply #76 on 12/11/2011, 10:46 »
Nice to see everyone is getting sorted Cheesy
« Last Edit: 12/11/2011, 10:49 by Mattz0r »
Logged
« Reply #77 on 12/11/2011, 11:04 »
We still need to sort out "smiles1984".  He has messaged me asking to explain exactly step by step how i managed to sort it the open NAT on ps3 MW3.  I have copied and pasted from this thread as its starting to get a bit of mess if you want to follow all the right steps in order ie
Set up the PS3 DNS settings
Make sure you can telnet with your version of windows
do the telnet commands including save
hey presto
[Moderator's note by Dick (Strat):  Full quote of preceding post removed, as per Forum Rule]
« Last Edit: 12/11/2011, 12:55 by Strat »
Logged
« Reply #78 on 12/11/2011, 11:48 »
Is there no way I can co this through my router then? (logging in through my ps3 browser) I have to have a laptop to fix the PS3?
Logged
« Reply #79 on 12/11/2011, 11:54 »
I suspect the ps3 wont support the telnet command shizzle and it will have to be a PC.  If you have a mate with a lappy, i would ask them round for dinner and ask them to take their computer  Smiley
« Last Edit: 12/11/2011, 12:57 by Strat »
Logged
Jump to:
Related Sites
Community Apps
About Plusnet
We're a Yorkshire-based provider selling broadband and phone services to homes and businesses throughout the UK. Winner of the ISPA 2010 'Best Consumer Customer Service ISP' Award, we're proud to offer the UK's best value standalone broadband.
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
