access forbidden error 403
- Everything else
- access forbidden error 403
28-10-2010 10:28 AM
I'm very new to all of this cgi and wordpress sites so...
My domain points to my CGI space, but the main domain is blocked and I get the following message
Access forbidden!
You don't have permission to access the requested directory. There is either no index document or the directory is read-protected.
If you think this is a server error, please contact the webmaster.
Error 403
www.conjureevents.co.uk
Thu Oct 28 10:16:22 2010
Apache
Following the instructions I set up the wordpress website in a sub folder called blog, and the domain points to this, but it doesn't work, if I put /blog in the end, it seems to work. Sort of.
I then get the ~stephenaryan/blog/ in the address and as soon as I move elsewhere, the address changes and shows my ccgi address.
I've read some stuff on the forum , mostly posted by Gabe, about an .htacess file, but when I created one of those following his instructions nothing changed. Any changes to the .htaccess file didn't do anything either.
I'm still puzzled why .co.uk is blocked, but .co.uk/blog sort of works.
Any help would be appreciated for a newbie to this.
Access forbidden!
Error 403
Apache
Message 1 of 5
(2,266 Views)
4 REPLIES 4
Re: access forbidden error 403
28-10-2010 12:50 PM
It looks like DNS points to your ccgi webspace top level and you get 'access forbidden' because you don't have an index.htm or equivalent file in that directory. If you want to redirect that to domainname/blog/ you need to do that using .htaccess.
Did you base the .htaccess file you created on Gabe's post here?
You also need to include the rule to deal with the (lack of) trailing slash problem mentioned later in Gabe's post.
I think links moving to ccgi addresses is most likely due to Wordpress being installed with that set as the home directory in the configuration file (so that is where the links point to).
David
Message 2 of 5
(667 Views)
28-10-2010 1:15 PM
Thank you for replying, I can see there are a few different problems that need sorting, but I think I can fix a couple of them without too many problems.
I'll refer to that link for the .htaccess file.
Message 3 of 5
(667 Views)
29-10-2010 11:40 AM
This problem has now been completely resolved.
First, because I'm not using my cgi space for any other websites, or any other Wordpress websites, it's not in a sub folder, so the index.htm file is now in the root.
Second, I adjusted the setup home directory in the Wordpress dashboard to point to the new location and it got rid of all the (tilda/username) in the urls
thanks again
thanks again
Message 4 of 5
(667 Views)
29-10-2010 1:58 PM
Thanks for this feedback. Glad to hear things are sorted now.
David
Message 5 of 5
(667 Views)
- Everything else
