Business user IP Space blacklisted at UCEProtect
- Business
- Business user IP Space blacklisted at UCEProtect
02-09-2010 1:49 PM
Hey,
This is in regards to MY mail server, not plusnets, but it is an issue to do with spam on the plusnet ip space.
I have had a few email bounce back to me over the last few months, but it has been so few that I haven't really looked into it until now.
If you go to: http://www.uceprotect.net/en/rblcheck.php and do a check, for example, on my ip 84.92.80.85 you will see that im *NOT* listed for sending spam, however, they have 3 levels, and level 3 is blacklisted because there are so many users on 84.92 which HAVE been blacklisted, and thus puts it over the threshold.
Can anything be done about this. As a business customer i dont want to use a smarthost, and I can't see plusnet block destination port 25 for residential customers.
Message 1 of 6
(7,488 Views)
5 REPLIES 5
Re: Business user IP Space blacklisted at UCEProtect
02-09-2010 3:13 PM
The normal configuration is to relay through the Plusnet mail servers. Your IP will probably be shown as being on a dynamic range of IPs (even though you have a fixed IP) and some mail servers will block you for that fact alone.
Message 2 of 6
(681 Views)
07-09-2010 8:42 AM
I have done a lot of search on many blacklists, especially blacklists which index dynamic ranges, and the IP is not blocked on any. Infact... my ip passes every blacklist I have tried.
The only two blacklists I have problems with is uceprotect in my above post because plusnet ip space is considered "spammy" and the following page:
http://www.apews.org/?page=test&C=40&E=168291&ip=plus.com
Which again comes down to plus.com considered to be a spammy domain.
If you want people to send via smarthost then why do you allow direct smtp outbound? Why not, at the very least, add port 25 outbound to the firewall rules you enable by default for customers.
I understand, that its practically impossible for you to control what users are sending outbound, but the default firewall you apply blocks inbound connections to the customers ip, so why not block smtp port 25 out as well? Most people that use other providers for mail should be set up to use the submission port anyway.
Message 3 of 6
(682 Views)
15-09-2010 7:18 AM
I think the real issue is that people are blocking mail because an IP space is listed at Level 3. It is meant as a warning. However, it is up to the end user how they configure their server.
The other thing that worries me is that it looks like Plusnet is not being tough enough on spammers in allowing this to happen. Have you raised a Ticket on this? posting here may not do anything
Rob
Rob
Message 4 of 6
(681 Views)
15-09-2010 8:19 AM
Yep - we had to smarthost through PNs relay servers too.
The issue wasn't so much that there was any issue, but as Rob says, some people misuse or misunderstand the ratings, and block mail. (Our biggest issue was with MessageLabs customers IIRC)
Message 5 of 6
(681 Views)
03-10-2010 12:22 PM
Has something been done about this?
Because I'm looking at the same page now and the amount of ip addresses listed has gone down by hundreds over the last 100 hours.
Or is this more likely down to microsoft releasing a patch?
Message 6 of 6
(681 Views)
- Business
