Sync and Profile (Again)
- Sync and Profile (Again)
14-12-2009 4:35 PM
Latest BT Speedtest:
Quote Download speedachieved during the test was - 3319 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :4540 Kbps(DOWN-STREAM), 920 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 17.57:21.69:60.74 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
I'm on 21CN. How can I get my BT profile and, hence, speed to rise that little bit?
Forum Moderator and Customer
Re: Sync and Profile (Again)
15-12-2009 12:59 PM
Thanks.
15-12-2009 1:01 PM
16-12-2009 4:22 PM
Att: 45
Noise Margin: 6
Latest BT speedtest:
Quote Download speedachieved during the test was - 3164 Kbps
Your DSL Connection Rate :5333 Kbps(DOWN-STREAM), 896 Kbps(UP-STREAM)
The throughput of Best Efforts (BE) classes achieved during the test is - 13.97:20.86:65.17 (SBE:NBE:PBE).
Is the BT profile, in time, liable to rise to match the sync and, therefore, I can request a rise in the PN profile?
According to Kitz I could get a profile of 4500.
16-12-2009 5:51 PM
18-12-2009 4:46 PM
I have noticed that even those with a sync rate of above 8000 can still show the lower acceptable range.
Why is this?
18-12-2009 5:29 PM
18-12-2009 5:32 PM
19-12-2009 12:21 PM
Can it be nudged up, please?
21-12-2009 11:09 AM
21-12-2009 11:32 AM
21-12-2009 11:36 AM
Quote The throughput of Best Efforts (BE) classes achieved during the test is - 17.57:21.69:60.74 (SBE:NBE:PBE)
as well as the acceptable range, sum will see the above QOS test and some wont. ive not seen it on any of my tests since april and this line even has elveted best effot on it. not the same as the above qos but you would think a line with what is a paid for QOS option would be more likely to see the above test
