@MisterW/bobboulby
Which routers do you use? I presume your Gigaset phones plug into a router and are not ADSL self-contained?
vof
Yep , the gigaset phones plug into an ethernet port on your router. I use a 2wire 2700HGV ( aka BT Business Hub ), it actually has voip ports on the router but they never gave very good quality. The fact that it has integrated voip probably explains why its SIP ALG works so well though.
I will try experimenting with the outbound proxy settings to see if they are needed, and the effect on traffic volume.
If you dont use the OB proxy, and dont have a working SIP ALG in your router, then you wont be able to receive incoming calls without some other configuration. Its possible, but tricky, to use port forwarding on the router and/or STUN to get incoming calls to work. It's going to be difficult in your case though since you have two lines on your ATA.
I realise that ~10MB/day is a fair chunk out of your PAYG package but have you considered changing to one of the current packages. If you're in a Market 3 area then the 'Value' package will give you 10GB/month for £5.99. Saving you cash and a lot more bandwidth to play with.
I changed to Value from PAYG about 6 months ago and am really pleased. However be careful of the traffic shaping on Value ( see here
http://www.plus.net/suppo...ity_broadband/speed.shtml ), if you use PTP,Usenet etc then you WILL notice a slowdown since PAYG is not shaped at all. However if you use your BB for general browsing, Email,Voip and occasional VPN like me then you wont notice any difference, apart from more money in your pocket every month!!
