my router stats
- my router stats
my router stats
14-07-2009 3:51 PM
Line Rate 8096 Kbps 448 Kbps
Attainable Line Rate 10880 Kbps 1132 Kbps
Noise Margin 14.2 dB 25.0 dB
Line Attenuation 0.0 dB 5.5 dB
Output Power 12.1 dBm 15.8 dBm
can someone tell me what these stats mean please and if they are good or bad and what could i do to fix em,thankyou very much
Re: my router stats
14-07-2009 3:57 PM
what router model is it?
can u see the bt exchange from your house?
Re: my router stats
14-07-2009 4:01 PM
Re: my router stats
14-07-2009 4:04 PM
Re: my router stats
14-07-2009 4:32 PM
if this at the right profile for your sync then they only major thing thats slowing speeds is plusnets traffic mangment unless your on the pro package. http://www.plus.net/support/broadband/quality_broadband/speed.shtml
Re: my router stats
14-07-2009 4:43 PM
Re: my router stats
14-07-2009 4:52 PM
its the current speed on the link i gave in my previous post thats of intrest. it may be a simple reboot of router to pick a updated PN profile up if its set at 7150 currently
Re: my router stats
14-07-2009 5:01 PM
Re: my router stats
14-07-2009 5:05 PM
Re: my router stats
14-07-2009 5:11 PM
Re: my router stats
14-07-2009 5:17 PM
Re: my router stats
14-07-2009 5:20 PM
If you run thr BT speedtester what does it say http://speedtester.bt.com/
Your login will be yourusername@plusdsl.net
Re: my router stats
14-07-2009 5:29 PM
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 1858 kbps
Re: my router stats
14-07-2009 5:32 PM
Re: my router stats
14-07-2009 5:49 PM
thanks for the info and too everyone who has got back to me here,i must say im liking plusnet,ive had more help and better customer care than ive ever had with tiscali the whole year i was with them,think i made a great choice leaving them and coming to plusnet,seems alot more helpful not to mention my STREAMING over xbox live has improved very much
Quote from: Oldjim Thought so - you will just have to be patient - it may even take 10days from when you were connected to catch up but optimistically it may only take 3 days
