Saturday 21st November 2009Login | Register | Help
Pages: 1 ... 53 54 [55] 56 57 ... 74
Product Refresh
  • Strat
  • Forum Moderator
  • View Profile
« Reply #864 on 22/02/2009, 17:21 »
You started it Wink
Plusnet Customer and Forum Moderator  Which gateway am I on and How is it Performing (Scroll down to your Gateway Graph)
Acronyms are a PITA
Logged
  • Oldjim
  • Forum Moderator
  • View Profile
« Reply #865 on 22/02/2009, 17:26 »
[Moderator's post by Jim (Oldjim) Please lets get it back on topic otherwise I am going to have to try to split out the off topic posts and I really don't want to as it's a bit too much like work for a Sunday  Roll Eyes ]
Jurassic Coast
Dorset Area Ramblers
Jim
Logged
  • Strat
  • Forum Moderator
  • View Profile
« Reply #866 on 22/02/2009, 17:30 »
Sorry Embarrassed
Acronyms are a PITA
Logged
  • Oldjim
  • Forum Moderator
  • View Profile
« Reply #867 on 22/02/2009, 17:31 »
Back on topic - in the FAQ for unlimited it states
3. How fast is it?
You'll receive the fastest speed your line will support, currently up to 8Mb. Faster ADSL2+ speeds will be available on our broadband products in the future.
Why is this conspicuous by its absence in the Value and Pro FAQ's even though the term "broadband products" is in the plural implying that it will be available on products other than unlimited.
« Last Edit: 22/02/2009, 17:32 by Oldjim »
Jurassic Coast
Jim
Logged
« Reply #868 on 22/02/2009, 17:41 »
It means that they will introduce a special value / pro account with ADSL2+
It will have a 300 month lock-in period.  Cheesy
Plusnet Customer Support (Sheffield) 0114-296-5198   Depending on your telephone provider, time of day etc it may be cheaper to use the 0845 number and possibly speak to South Africa.
Logged
  • pd
  • View Profile
« Reply #869 on 22/02/2009, 17:52 »
It has been mentioned a couple of times that this is only the first phase of PNs plans.  Anyone care to speculate what the next phase is likely to bring?
Peter
Metronet PAYG  2003-2008 ::: Plusnet BBYW2  2008-? :::  Plusnet VoIP help for Asterisk
Logged
  • Strat
  • Forum Moderator
  • View Profile
« Reply #870 on 22/02/2009, 17:53 »
A 12 months contract Smiley
Good tactic actually. Move from 1 month to 18 months and shell-shocked customers will 'happily' accept 12 months as a compromise Wink
« Last Edit: 22/02/2009, 17:56 by Strat »
Acronyms are a PITA
Logged
« Reply #871 on 22/02/2009, 18:00 »
I won't! I'm with Kitz. If I need to change products and am subjected to the indignity of anything more than a 30 day contract, I'm taking my MAC and leaving.
Wheel_nut
PlusNet BBYW Pro - Lite Customer from Feb 2009
NewNet Customer  2007 - Feb 2009
PlusNet Customer 2003 -  Feb 2007
Logged
  • Mand
  • Plusnet Staff
  • You live and learn. At any rate, you live.
  • View Profile
« Reply #872 on 22/02/2009, 19:10 »
I'm probably being thick or trying not to see the answer I don't want but I don't understand the terms Fixed and Flex.
Are you saying that Value customers don't get continued connection albeit restricted to 128Kbps after they reach their 10Gb or paid upfront extension?
If so, that is a very retrograde step and anyone considering switching from BBYW should consider this carefully.
Apologies for any confusion caused. Fixed or flex are BBYW terms. When signing up (and later via the Member Centre) you could choose to either buy a set amount of extra bandwidth each month and be restricted after that (fixed) or have usage added as you used it (flex).
On the new products you either set a Data Transfer Watch amount (equivalent to the fixed option) or have usage added as you use it (equivalent to flex). The difference being that you don't get throttled to 128k after using your additional bandwidth on the new products, you are either restricted or have the choice to buy more bandwidth.
  • Oldjim
  • Forum Moderator
  • View Profile
« Reply #873 on 22/02/2009, 19:16 »
Mand - in this context  does restricted mean that you can only go to the portal to add new bandwidth or can you still browse at 128kbps
Jurassic Coast
Jim
Logged
  • Mand
  • Plusnet Staff
  • View Profile
« Reply #874 on 22/02/2009, 19:16 »
So if you are on a physically BT Wholesale provided piece of phone line (i,e, not cable) but pay your phone line rental bill to a WLR provider like www.yourcalls.net as I do then Plusnet isn't actually interested in having me as a customer unless I also move my phone line rental back to BT, even though I am on a non LLU exchange (Market 1) and so would be paying the higher monthly cost that reflects the fact there is no LLU competition.  In other words Plusnet is now BT by any other name and not an independent operator merely ultimately owned by BT since it is trying to force people to also take phone calls from it when they become customers and they cannot take just the broadband service alone.  Your packages page doesn't seem to suggest this though as it is still possible to take them without phone line rental and calls packages I thought?  Or do you just mean the physical phone line must be owned by BT Wholesale and not that the customer must have their phone line rental with BT?
That phrase is referring to the underlying line being a BT Wholesale line, not necessarily through Retail. Again that's a standard term, across the industry. We cannot provide broadband over a fully unbundled line, or a cable line.
Precisely because its not on the main page and its only in small print that many customers will miss on the next page. Roll Eyes
It's detailed further in the signup journey too.
So Plusnet is now abandoning any aspirations to serving demanding broadband customers looking for a high quality service and is only interested in being a cheap and nasty broadband supplier with the same heavy throttling for all customers on what are laughably called "unlimited" broadband products as is applied by Orange and Tiscali it appears (TalkTalk at least concede they have a 40Gb download cap, although given their heavy throttling it would be quite hard to exceed it).  I don't think Sky/Easynet can be tarred with quite the same brush as their throttling regime is nowhere near as bad as the one Plusnet is proposing for P2P on its so called unlimited product.
So Plusnet has now turned in to an Orange or Tiscali type broadband supplier and you personally and your board are unapologetic about that downmarket move?
So do new broadband customers who want a completely unthrottled broadband service from the BT group now have to take their business to www.madasafish.co.uk then?  Ironically a service that is underlyingly delivered by Plusnet. Huh? Undecided
We've not turned into anything. We're still Plusnet. We want to be the best value broadband provider, whatever kind of service you're looking for.
If you want a completely unmanaged product, priced accordingly, Pro is the appropriate product. If you're looking for more usage, and happy to accept a speed trade off at certain times on certain protocols then the other products are aimed at you.
  • Mand
  • Plusnet Staff
  • View Profile
« Reply #875 on 22/02/2009, 19:19 »
That's because all of the other big boys apart from the BT group are driven by whether or not they have an LLU presence in terms of being able to offer lower prices.   The other big boys will basically nearly always have an LLU presence on a Market 3 exchange so whether or not pricing with them is cheaper is driven by whether or not they have an LLU and not the Ofcom Market classification.
What is interesting to speculate on is whether the independents with no LLU or next to no LLU like Newnet, IDNet, Zen and Entanet will now bring in lower pricing in Market Three areas, given that BT Wholesale would be able to give them cheaper prices in those areas.  On the whole I suspect they won't do this as most of their customer base is in Market 1 and Market 2 areas so they would upset them by offering cheaper prices that they cannot access.
How other companies choose to use the discount is upto their marketing strategy I would imagine.
We've chosen to apply the discount where it is applied, and aim to compete with the LLU providers in those areas. Obviously there is competition there, or the exchange wouldn't be a Market 3 exchange in the first place.
  • Mand
  • Plusnet Staff
  • View Profile
« Reply #876 on 22/02/2009, 19:24 »
How long are the legacy products and their extras going to last?
I can't see them disappearing altogether to be honest. When I last checked we had a handful of customers on products from as far back as 6 years ago.
Will the extras be sidelined in terms of performance and support, unless they call on the likes of your good selves here to fix things?
Nope, but our team is always here if you have any questions.
Why is extra bandwidth only available in 2Gbs now and why has the price increased?
The price is comparable to the BBYW additional usage pricing (before the marginal VAT decrease anyway, it was rounded up to £1 per GB for simplicity). Most customers who buy additional usage buy more than 1GB, so I can't see this being too big an issue.
If you are giving extra bandwidth to the BBYW3 as unlimited, why not give Pro users an improvement to 20Gb?
I'm not sure what the question is here, we haven't made any changes to any of the BBYW products?
Why can't existing customers have a one time change if they like the differences with product refreshes, without changing contract length, with no new equipment or costs?
All the new products have an 18 month contract as default. Obviously that's where most of the negative feedback has originated in this thread, and that has been passed on to the rest of the business.
« Reply #877 on 22/02/2009, 19:28 »
Plusnet have been adding more capacity recently.  Thing is, do they plan to keep adding capacity through the next year or two, if the influx of new subscribers accelerates as they expect?   ie, in short, will the pipes become more/over congested?
Logged
  • Mand
  • Plusnet Staff
  • View Profile
« Reply #878 on 22/02/2009, 19:33 »
She was working this morning, think she'll need a holiday soon.  Smiley
Don't worry, I got the weekend off. Smiley
I just can't keep away from you lot. Wink
  • Oldjim
  • Forum Moderator
  • View Profile
« Reply #879 on 22/02/2009, 19:36 »
Mand - to clarify my previous question.
The broadband FAQ states
12. Can I restrict how much I spend on extra data transfer?
Yes. Use the Data Transfer Watch tool (only available on Plusnet Value, Plusnet Pro, Broadband PAYG and Broadband Your Way accounts) at the Member Centre. This allows you to set a maximum amount that you are willing to spend on extra data transfer each month.
Note: These restrictions are applicable at all times once you have reached your chosen data transfer limit.
But the restrictions, which used to be defined for BBYW), are not stated anywhere
Jurassic Coast
Jim
Logged
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
