So slow....
- So slow....
So slow....
20-12-2008 8:34 PM
Paranoid me wonders if this is related to the sign up for longer at a reduced rate, maybe not such a good deal after all???
Going
Re: So slow....
20-12-2008 8:42 PM
1) result from http://speedtester.bt.com/
2) stats from your router, such as synch speeds attenuation and margin
3) line speed from here https://portal.plus.net/my.html?action=data_transfer_speed
Re: So slow....
20-12-2008 9:11 PM
- See attached
Quote from: adiewoo Can you post:
1) result from http://speedtester.bt.com/ - Only get 'Test Error' when trying to run process
2) stats from your router, such as synch speeds attenuation and margin - Not quite sure on how to get this info ?
Re: So slow....
20-12-2008 9:17 PM
http://kitz.co.uk/adsl/frogstats.php
Re: So slow....
20-12-2008 9:26 PM
Quote from: MOGO - See attached - Hopefuuly this is the data
jim:green security information blanked in the image mod:end
Re: So slow....
20-12-2008 9:30 PM
as a further check does this link http://usertools.plus.net/@gateway/ ; give the result This gateway is sometimes known as thn-ag2
Re: So slow....
20-12-2008 9:49 PM
That's the one shown!
Re: So slow....
20-12-2008 10:04 PM
As the reps are in short supply this evening I am not sure what we can do. You could raise a ticket but this would need to be addressed by the networks team and they don't normally work weekends.
I know it is a pain but could you hold off until Monday when we should have more reps on board.
P.S You will see I have modified your router stats picture to hide the security related information
Re: So slow....
20-12-2008 10:21 PM
Re: So slow....
21-12-2008 12:14 AM
In the Internet Settings I see you have the WAN subnet mask set to 255.0.0.0 which should be set to 255.255.255.255 if you have only a single IP address with Plusnet! They couldn't issue a block of IPs large enough to need your WAN subnet mask! (The LAN settings subnet mask 255.255.255.0 is correct.)
So, I'd correct that, save the settings and reboot the router and see if it makes any difference. It might, it might not! But it'll be right!
If you have your WAN IP address set to 'obtain automatically', and it is being issued a subnet mask of 255.0.0.0 there must be a bug somewhere!
Re: So slow....
21-12-2008 1:45 PM
Many thanks for the tips on security and protocol
MOGO
