21CN: any improvement onstability for long/sub-prime lines
- 21CN: any improvement onstability for long/sub-pri...
20-11-2008 1:53 PM
I'm started this thread so that I don't incur the wrath of PN staff/mods as I'm not likely to be a trial candidate.
Jamesh is currently looking to see if we can get my line stable as its up and down (as its long and sub-prime) so hats off to him for that.
It looks as though the emphasis is upping the speed again which is great of course (though still a long way from the 100 meg I enjoy at work
However there does not seem to be any tweaks to improve stability or is there something I've missed?
Re: 21CN: any improvement onstability for long/sub-prime lines
20-11-2008 2:43 PM
So what next? Undoubtedly, as with current routers, there will be enhancements to what can be achieved - but I have to say that there seems limited optimism in the industry for any significant change. Other technologies are being worked on, but fibre deployment does seem to be the next logical step - and it ain't cheap.
20-11-2008 3:38 PM
All of the buildings where I work are linked with fibre for that reason.
21-11-2008 10:45 AM
DLM is being improved to be more intelligent, so the changes in IP Profile should be worked out more "intelligently" and faster, so whilst there won't be an improvement in stability as such, the speed at which changes occur should be improved.
21-11-2008 2:47 PM
21-11-2008 4:23 PM
Maurice
21-11-2008 4:30 PM
I just want them to hurry up with fibre and maybe Ethernet from a street cabinet to the home.
25-11-2008 5:12 PM
25-11-2008 5:22 PM
So, you're using twice the number of frequencies to transfer (up to) 3x the amount of data that ADSL does. That's why ADSL2+ is much more susceptible to interference and attenuation losses that ADSL is.
That being said, I suspect that natural improvements in technology will make the available bandwidth on ADSL2+ generally higher than ADSL even on "slightly more dodgy" lines eventually.
B.
25-11-2008 5:33 PM
25-11-2008 5:54 PM
Was a right pain.
26-11-2008 8:47 AM
Quote from: Barry The ADSL2+ specification allows for *downstream* data bits to be transmitted in the 0.14MHz - 2.2MHz band., whereas ADSL allows for downstream transmission to occur in the 0.14MHz - 1.1MHz band.
I don't suppose that anyone is technically mind enough, and has read the spec, to know if sub-optimal lines will pick the best frequencies in the new range for stability rather than throughput?
i.e. If you can't get a stable line on ADSL 1 due to interference, solar flares, etc, will the new standard attempt to just operate in the newly available 1.2-2.2 band, or does the spec require that the full frequency range is used?
Just some pre-work, pre-caffine assimilation ramblings.
A.
ps. if no-one has thought of that, i call patentsies on the idea!
26-11-2008 9:04 AM
The only critical frequency is the ADSL pilot tone, which nominally sits around 280 kHz. This acts as a communication frequency that the CPE equipment and the DSLAM use to negotiate sync changes without dropping the connection (amongst other things). If there is any REIN or interference around this tone then it is unlikely that ADSL equipment will function at all (let alone ADSL2+).
So, if you have a line that is currently unstable, then ADSL2+ *may* benefit you as it is perfectly feasible for it to use just the >1108kHz frequencies - as long as the pilot tone survives.
B.
26-11-2008 9:13 AM
26-11-2008 12:03 PM
Quote from: darkskye
This is an inherent part of ADSL2+, it is called Seamless Rate Adaption (SRA). The line is monitored/analysed at all time to 'see' if there are channels that can be used if not already, and to stop using any channels if they have become noisy.
My speculation, for most of the daytime when noise and interference is low, your modem will give a 'Sync Speed' that is high, and from 17:00 to 05:00 the next morning the speed will be lower. Hopefully though, these changes in speed are expected to be seamless!
It could be the Be/O2 implementation, as described below had problems, and BT have something else planned but based on SRA. Only time will tell!
SW.
3Mb FTTC
