Saturday 21st November 2009Login | Register | Help
Pages: [1] 2
email icon
  • dgdclynx
  • Usergroup Member
  • Marty the house cat
  • View Profile WWW
« on 07/04/2007, 05:26 »
When I click on it I get an error message. When setting up my profile I asked for email address to be hidden which may be relevant.
Douglas Clark ..................... Bath, Somerset, UK ......
http://usergroup.plus.net .......... http://www.dgdclynx.plus.com
Logged
  • dgdclynx
  • Usergroup Member
  • View Profile WWW
« Reply #1 on 07/04/2007, 05:30 »
I am probably trying to send email to myself and it dont like it.
Logged
  • dgdclynx
  • Usergroup Member
  • View Profile WWW
« Reply #2 on 07/04/2007, 05:33 »
No. I clicked on Bilbo's email icon and got the same error msg: You cannot send Email.
« Last Edit: 07/04/2007, 07:54 by dgdclynx »
Logged
  • spraxyt
  • Usergroup Member
  • View Profile
« Reply #3 on 07/04/2007, 12:54 »
I can't send email to you either, or to someone else I tried.
I also asked for my email address to be hidden but the icon appears in my posts.  I suspect the request is being honoured but showing the email icon seems to be an anomaly.
Logged
  • jtn
  • View Profile
« Reply #4 on 07/04/2007, 13:07 »
Hi David.
The only icon I can see under your name is send a pm icon and the profile one.
Cheers
Jon
edit to add.
the hide email address thing is to do with whether it shows up in your public profile or not, rather than if you allow them.
« Last Edit: 07/04/2007, 13:16 by jtn »
Logged
  • spraxyt
  • Usergroup Member
  • View Profile
« Reply #5 on 07/04/2007, 13:23 »
Hi Jon,
This gets curiouser and curiouser.  Originally those are the only icons I could see against your post.  I started a reply then went back to your post, could see an email icon then (in the middle of the others).
Wondered if I'd been mistaken originally, so looked in another thread, then came back here and your email icon had vanished again!
 Huh?
Regards
Logged
  • jtn
  • View Profile
« Reply #6 on 07/04/2007, 13:35 »
Hi .
Not sure what is happening here. I've changed the email settings a couple of times but what is shown doesn't seem to relate to the changes. Could be a browser cache thing, I don't know.
Do you see my email addy when looking at my profile?
Cheers
Jon
Logged
  • spraxyt
  • Usergroup Member
  • View Profile
« Reply #7 on 07/04/2007, 13:42 »
Hi Jon,
No, it says "hidden".
I wonder if the email icon appeared transiently, then disappeared again if you were changing settings while I was doing the previous post?
Logged
  • jtn
  • View Profile
« Reply #8 on 07/04/2007, 19:37 »
Hi.
Looks like I was wrong on the hidden/not hidden stuff regarding whether an email can be sent or not(from what I can see anyway). Not sure what's up with the icons
Cheers
Jon
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #9 on 10/04/2007, 08:40 »
Still happening?  Seems fine to me.  I either get a "user has hidden email address" message, or a box to send them email.
Plusnet: Head of Platform and Operations
Logged
  • dgdclynx
  • Usergroup Member
  • View Profile WWW
« Reply #10 on 10/04/2007, 10:35 »
Just reporting that I got James_H's email. Still puzzled at to why I cant send. I would have tried sending one back to James but he doesnt have an icon.
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #11 on 10/04/2007, 10:54 »
Can you send to me?
Logged
  • dgdclynx
  • Usergroup Member
  • View Profile WWW
« Reply #12 on 10/04/2007, 10:58 »
No Kelly.
Logged
« Reply #13 on 10/04/2007, 12:58 »
I think in an un-moddes SMF, it hides the icon as SMF does unobscured emails by default. I installed a Mod that let it use that form instead though, which may not be working correctly...
Kind Regards,
Colin Ogilvie
Plusnet Application Developer (until June 12th 2009)
Get next generation speeds - Join the ADSL2+ trial!
Logged
  • spraxyt
  • Usergroup Member
  • View Profile
« Reply #14 on 10/04/2007, 16:06 »
Can you send to me?
I just tried to email Kelly; whether I click the icon shown under the username or the Email User button in Kelly's profile I get the error message:
An Error Has Occurred! (shown on a purple strip)
You can not send email.
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #15 on 10/04/2007, 16:21 »
Ok!  Cheers!
Logged
Pages: [1] 2
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
