Line fault fixed - still slow
- Line fault fixed - still slow
07-08-2007 11:42 AM
See previous post - Sudden Slowdown.
Thanks to swift response from F9 and BT, a noisy line has now been fixed.
How long will it be before my connection speeds up again?
speedtester.bt.com is reporting
Assured Rate IP profile on your line is - 750 kbps
Actual IP throughput achieved during the test was - 449 kbps
The BT engineer was getting speeds of 2.9 meg on his kit, and my router is reporting
DSL Status: Up
DSL Modulation Mode: GDMT
DSL Path Mode: INTERLEAVED
Downstream Rate: 6144 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 13 db
Upstream Margin: 23 db
Downstream Line Attenuation: 38
Upstream Line Attenuation: 20
Downstream Transmit Power: 0
Upstream Transmit Power: 0
Does my profile have to be reset?
DSL Status: Up
Message 1 of 2
(2,259 Views)
1 REPLY 1
Re: Line fault fixed - still slow
07-08-2007 11:44 AM
It's likely that the speeds will increase naturally due to the nature of MaxDSL. As long as you sync at that same speed for 3 days it will increase to a profile of 5000 as per the table on this page.
Message 2 of 2
(405 Views)
