ZyXEL Prestige 2002 (P2002)
ZyNOS Firmware Version: V3.60(MD.4) | 08/22/2005
VoIP PageSIP Settings:
- SIP Number: <Your SIP ID>
- SIP Local Port: 5060
- SIP Server Address: sip2.plus.net
- SIP Server Port: 5060
- REGISTER Server Address: sip2.plus.net
- REGISTER Server Port: 5060
- SIP Service Domain: sip2.plus.net
Authentication:
- Authentication User ID: <Your SIP ID>
- Authentication Password: <Your SIP password>
Press Advanced Settings button to display Advanced VoIP Settings page if you want to set the Outbound Proxy:
Outbound Proxy:
- Active: Checked
- Server Address: nat.plus.net
- Server Port: 5082
Forgive my ignorance, is the SIP proxy setting the Outbound Proxy section and if so, does nat.plus.net go in the Server Address field and 5082 in Server Port field?
My existing menu has no value in either STUN or Use NAT sections, per PlusNet's instructions for the 2002L. Is that OK?
I don't understand the comment about the non-proxy option in your 'phone book! Again, sorry!
Yes, you're correct. Try it without any proxy settings first. Mine works fine without it on SIP and PSTN calls.
You really only need the Outbound Proxy set if you want to call another SIP ID, for example sip:123456@draytel.org, which of course you can't dial on your telephone. In this case I would either use the prefix for a peered network (see
http://community.plus.net...dex.php/topic,1654.0.html), which in this example would mean that I would dial **372 123456 on my telephone, or set up a speed dial in my phone book on the P2002.
In the phone book add a speed dial, for example, on #01 enter 123456 in SIP Number and, in Type, select Non-Proxy and enter draytel.org. Then you can just enter #01 on your phone to call
123456@draytel.org.
If you activate the proxy, then in your phonebook you could add
123456@draytel.org in SIP Number and leave the type as Use Proxy, which will then use the proxy to work out how to get to draytel.org. I've found though that I've never had to do this and prefer to leave my proxy settings off.
Hope this helps.
Regards,
Mark
