Saturday 6th February 2016Login | Register
Pages: 1 [2]
BT Green Box
« Reply #16 on 12/04/2004, 18:03 »
No, I think you're all wrong.
It is actually part of cqg4uzg's 2Kw bird frying linear amp.
He has obviously removed the valves to ensure that I cannot see what they are!!
I believe they normally reside in the white socket box..
Regards
Dave
Logged
  • smithclan
  • Guest
« Reply #17 on 12/04/2004, 22:18 »
Can't believe you swapped your type-R for an antenna!
Logged
  • cqg4uzg
  • Guest
« Reply #18 on 12/04/2004, 22:40 »
Ok, I knew that.  You can see the Philips Magnavox digital distribution node (the silver box). The NTL phone distribution is on the right.
The BT boxes that remain are very similar from the outside. Now, most new BT distribution boxes are underground in manholes. However, they suffer with being filled with water if the drainage is bad.
Anyhow, point I was making was, don't  blame PlusNet if your DSL goes down. There is a whole BT network, between you and PlusNet.
Logged
  • cank1
  • Guest
« Reply #19 on 13/04/2004, 12:45 »
A "BT Green Box" or properly known as a primary connection point or "Cab" is always above ground to allow access. It is a flexibility point for connecting any Exchange pair of wires to any Distribution pair of wires in the local loop.
The street cabinet looks very similar to CATV street cabinets and BT usually get the fault report first, this used to be a high priority callout to go and close.
If your Broadband is down, check for dial tone - not fool proof but if no dial tone or "crackly" then probably  a BT fault
Jeff - ex-BT Engineer
Logged
  • brookyz7
  • Guest
« Reply #20 on 16/04/2004, 11:55 »
Woah  :shock:   Surely the point of encasing the wires is to protect wire from element and human from wire...I know it must take O, 5 seconds to open the doors, but it isn't that difficult
Logged
« Reply #21 on 16/04/2004, 12:50 »
And they might at least brighten it up with some of those cold cathode lights and flashing LEDs...
Pat.
Logged
  • acarr
  • Guest
« Reply #22 on 16/04/2004, 14:12 »
LOL, www.exstreme-overclocking-bt-style.com
Oh the thought of it
Logged
  • Peter Vaughan
  • Usergroup Member
  • Unofficial legendary bright spark bod!
  • View Profile
« Reply #23 on 16/04/2004, 16:13 »
bad link
plusnet ADSL Customer (PlusNet Pro)
PlusNet Usergroup | PUG Forums | Usertools | PUG Issue Tracker - Please vote!!
Volunteer at the National Museum of Computing @ Bletchley Park
FTTC unlimited syncing @ 77Mbs down / 18Mbs up, Data rate 62Mbs down / 14Mbs up
Logged
  • Be3G
  • Bright Spark
  • View Profile
« Reply #24 on 16/04/2004, 18:17 »
I think it was a joke, Peter. Tongue
Thomas
Thomas Kuglin known as kuglin on the old vISP forums.
Former vISP forum and latterly Community moderator, and operator of the dearly departed usertools IRC.
My web presences: twitter | flickr | last.fm
Logged
  • cqg4uzg
  • Guest
« Reply #25 on 16/04/2004, 18:25 »
Someone must have read this thread, the doors are back on !!!!!
Logged
  • smithclan
  • Guest
« Reply #26 on 16/04/2004, 22:09 »
'til the morning.....!
Logged
Pages: 1 [2]
Jump to:
Related Sites
Community Apps
About Plusnet
We're a Yorkshire-based provider selling broadband and phone services to homes and businesses throughout the UK. Winner of the ISPA 2010 'Best Consumer Customer Service ISP' Award, we're proud to offer the UK's best value standalone broadband.
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
