Below are the headers from a recently missed spam which came through the CP boxes. Is the X-MAA line added by CP? - if so it was right!
Yep, that's the beauty! The Exim config to get the subject line altered for these emails is likely to be done early next week.
What are the chances of re-zeroing the graphs for the CP appliances?
I don't think this is possible. It will fix itself over time though. Incidentally nothing could be seen on the graph even before the blip!
In addition, it appears that mails passing through the CP boxes are still being run through the DSPAM process (on sunmxcore-09). I'm guessing that when you're happy with the CP rollout, the sunmxcores will be relieved of this duty - allowing much more throughput?
Remember, the Critical Path roll-out is a trial so it's quite likely that it will be removed at some point before a long term decision is made. It makes sense therefore to leave dspam running.
What we'll probably do before the trial is out is configure the Critical Path boxes to refuse the messages it identifies as definite spam for a 24 hour period or so instead of deliver them. I'm sure after a few days of the CP boxes tagging subject line, customers will have no qualms about this.
I appreciate that the CP boxes are not 'tagging' the spam as yet. However, perhaps an interim X-Header tag would be useful so that customers who receive mail pathed through the test system can identify potential spamminess/hamminess of the CP solution?
As per Jelv's suggestion you can use the X-MAA headers.
Anyhow, so far it's looking good. I reckon Bob should be popping the kettle on in celebration
You've obviously not heard about my reluctance to make tea for the team
