Saturday 21st November 2009Login | Register | Help
Pages: [1]
No warning of comment going into moderation
  • Kelly
  • Plusnet Staff
  • View Profile
« on 05/04/2007, 10:22 »
If you are going into moderation with a comment, there is no warning, nor any indication that your comment was successful.
Plusnet: Head of Platform and Operations
Logged
« Reply #1 on 05/04/2007, 10:29 »
Just about to post this!
Logged
  • spraxyt
  • Usergroup Member
  • View Profile
« Reply #2 on 14/04/2007, 23:35 »
I added a comment on the BBYW: The questions were were asked blog which seems to have disappeared into thin air.
Does the bug referred to here mean it will have gone into moderation?  I notice some blogs have comments which implies the comment facility does work.
Regards
David
Logged
« Reply #3 on 15/04/2007, 00:18 »
I can only say 'Probably' as I don't have access to the backend for that particular blog so can't check.
Kind Regards,
Colin Ogilvie
Plusnet Application Developer (until June 12th 2009)
Get next generation speeds - Join the ADSL2+ trial!
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #4 on 15/04/2007, 11:09 »
Yep.  It will appear on Monday when one of the comms team approves it.
We definitely need to make that a little more user friendly.
Logged
  • spraxyt
  • Usergroup Member
  • View Profile
« Reply #5 on 15/04/2007, 11:39 »
Thanks, it is certainly confusing as it stands.
Logged
« Reply #6 on 16/04/2007, 09:20 »
This should now be resolved... it's nice when other people file the bugs for you and you can get patches written by the authors of the software Smiley
Kind Regards,
Colin Ogilvie
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #7 on 16/04/2007, 11:59 »
resolved, locked and moved.
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
