Am I being throttled when using a VPN?
- Am I being throttled when using a VPN?
07-03-2016 7:31 PM
Hi
I've noticed I am having significantly reduced speeds when I'm connected to a VPN service (ProXPN as it happens).
I have a Plusnet Hub One router, which is connected via ADSL as I only have fibre to the local cabinet, not to the house. My laptop is connected to the router via Ethernet.
Did a speedtest this evening. With no VPN I get 53.5 Mbps average down and 18.2 Mbps average up (a fairly typical speed for my connection). With VPN enabled I only get 14.4 Mbps down and 3.9 up.
Needless to say this is rather frustrating, and not something I ever had with my previous ISP (Sky). It certainly appears like I am being throttled, but Plusnet says they don't throttle. So I wonder what is happening, and whether there's anything I can do about it. All advice welcome.
Many thanks
Many thanks
Message 1 of 7
(3,504 Views)
6 REPLIES 6
Re: Am I being throttled when using a VPN?
08-03-2016 2:11 PM
Surely when using a VPN you are testing the VPN endpoint speed.
Google "whats my ip" with and without VPN
Ian
Ian
Message 2 of 7
(2,944 Views)
08-03-2016 4:07 PM
We don't apply speed limits to you if you're using a VPN, so that's not the issue here.
As you're on FTTC I'll ask the moderators to move this to the relevant forum.
Quote which is connected via ADSL as I only have fibre to the local cabinet, not to the house.
Message 3 of 7
(2,944 Views)
08-03-2016 4:11 PM
Quote from: Foxearth Did a speedtest this evening. With no VPN I get 53.5 Mbps average down and 18.2 Mbps average up (a fairly typical speed for my connection). With VPN enabled I only get 14.4 Mbps down and 3.9 up.
as you are using a VPN, you will be restricted to what the VPN endpoint is supplying you with.
thus, the problem is with your VPN, not your ISP.
Message 4 of 7
(2,944 Views)
08-03-2016 5:34 PM
Thanks for the replies, all. I wasn't sure but good to know it's not Plusnet anyway.
I'll scour the VPN forums to see if there's anything I can do to speed things up a bit!
Message 5 of 7
(2,944 Views)
10-03-2016 4:06 PM
With HotSpot Shield VPN configured for Japan (IP 122.152.167.250) I get a browser (Firefox) download speed of 66.89mbs but only 3.89mbs upload but with VPN disabled (IP 46.208.7.71 London) I get 70.9mbs download and 18.91mbs upload speed when tested via the Ookla webpage so the Plusnet FTTC is happy to support HotSpot
Message 6 of 7
(2,944 Views)
10-03-2016 4:26 PM
Don't forget you have an encryption overhead when working with a VPN. With enterprise hardware this doesn't usually introduce any delay but home / domestic kit you might notice some additional latency and also a drop in bandwidth. Not to mention that things are going to be slower if you're routing everything via a server in Japan - regardless of VPN or not.
Message 7 of 7
(2,944 Views)
