'Could not connect to database'
- Everything else
- 'Could not connect to database'
06-09-2007 9:46 AM
Quote phpBB : Critical Error
Could not connect to the database
Does anyone know why this happens?
Thanks,
Alan
Re: 'Could not connect to database'
06-09-2007 10:02 AM
Has this only started happening recently i.e. has your forum been working fine up until now or is this a new install you are testing?
06-09-2007 10:05 AM
im on rampus
06-09-2007 1:50 PM
06-09-2007 1:58 PM
Quote from: Chris Yep, we've had a few hiccups with rumpus getting very close to the limit and causing this type of error. We have an internal problem raised, if we get a lot more reports we can up the priority of it.
There's been a few reports of it scattered around other threads if I remember correctly. Just so you know
06-09-2007 2:03 PM
06-09-2007 5:56 PM
06-09-2007 10:09 PM
Did not connect to MySQL due to database error. Page reloaded and this time connected.
Happened with two entirely different php-programs.
08-09-2007 9:28 PM
When I surf to my page, the first message is:
Quote Database Error
The current username, password or host was not accepted when the connection to the database was attempted to be established!
Only after several attempts does the page then display.
It had never been that bad before - incredible! Why is there a problem? Is rumpus that slow???
09-09-2007 2:59 PM
09-09-2007 3:04 PM
09-09-2007 8:56 PM
I'm also on Rumpus and use my server for testing database applications such as Joomla, WordPress etc.
I suspected that my database might be corrupted or something but if others are having the same issue then it must be server related as opposed to just me.
Do the PlusNet staff suggest we raise tickets or will the evidence of a problem be gathered here?
Regards
James
10-09-2007 12:23 AM
10-09-2007 8:49 AM
Why don't PlusNet acknowledge the problem on the Status page?
10-09-2007 12:37 PM
Over the weekend everything has been fine, great, working a treat but this morning im getting database access errors again
I only just closed the ticket, guess i'll open a new one.
- Everything else
