Best easy to use linux for laptop
- Best easy to use linux for laptop
30-04-2014 2:13 PM
hi, were I do voluntary work, I have two Vista Laptops I am giving away , but today I tryed a system restore on one and bascily the DVD is damaged and I have no way of getting hold of it, so I Tought I may try Linux but what one is the easy one to install, I herd of Ubuntu, anyway any ideas thanks.
6 REPLIES 6
Re: Best easy to use linux for laptop
30-04-2014 2:18 PM
I recommend Linux Mint.
I've been using it for several years now and not switched to anything else.
30-04-2014 2:18 PM
I'd recommend giving this one a go (32 bit as I assume older Vista laptops won't 'need' 64 bit and 32 bit should be more compatible with some components):
http://www.linuxmint.com/edition.php?id=103
You may also want to try this (for installing via USB), might be a bit quicker especially if you've a couple to do:
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
Call me 'w23'
30-04-2014 2:19 PM
If you want one that looks like a mobile phone screen, Ubuntu is very good.
If you want one with a Windows-like menu, then a derivative of Ubuntu - "Mint" would suit.
Try to install a LTS (Long Term Release) version.
30-04-2014 2:20 PM
I can thoroughly recommend the much improved latest "Trusty Tahr" release v14.04 - http://www.ubuntu.com/desktop
If you don't get on with the Unity desktop, then try the Gnome desktop using the instructions here - http://www.omgubuntu.co.uk/2014/04/ubuntu-14-04-classic-gnome-flashback-session
30-04-2014 2:26 PM
Thanks for the replys I am just downloading Linux Mint now so I see how it goes.
13-05-2014 10:44 PM
Kubuntu is very nice to use. http://www.kubuntu.org/getkubuntu
