BT Home Hub 5
timsheffield
BT Home Hub 5
Can anyone help with  setting this up to use with Plusnet Fibre. Or is it not suitable.
Tim
7 REPLIES 7
Fixes: 392
Re: BT Home Hub 5
Should work fine. See these threads http://community.plus.net/forum/index.php/topic,119697.0.html & http://community.plus.net/forum/index.php/topic,118173.0.html
timsheffield
Re: BT Home Hub 5
Thanks it's up and running well great router and good wifi thanks for help
Tim
ScottJames
Re: BT Home Hub 5
Hi timsheffield
Just wondered if you purchased your Home Hub 5 online? If you did where did you get it from?
Thanks  Smiley
jamesanstee
Re: BT Home Hub 5
I purchased a BT Home Hub 5 back in november directly from the BT shop online @£129.00 though could be much cheaper now that the sales have started .
ScottJames
Re: BT Home Hub 5
Thanks for the reply jamesanstee. There is a place on Amazon doing it for £85. Every where else seems to be £129 and I am trying to figure out why this other place is so cheap!
HNKS
Re: BT Home Hub 5
I got one from ebay for £55. Madness paying more than that for it.
ScottJames
Re: BT Home Hub 5
Well I managed to get a new HH5 off of eBay. Hopefully it will turn up the day that I have my install.
Thanks for the replies from everyone  Smiley
