Plusnet Assist says it Doesn't Support My IE Browser
- Plusnet Assist says it Doesn't Support My IE Brow...
22-12-2013 3:29 PM
I am having problems with connection but only in the evenings. I have been given complicated instructions to test my router and filters though what use is this if broadband is up and running and the problems are only intermittent.
Has anyone else had these problems and what did they do?
I tried to access PlusNet Assist, which I downloaded, but keep getting the message ' PlusNet Assist does not support this browser' despite the fact that I have Internet Explorer 11 installed and no other browser. PlusNet Assist informs that it supports IE 6 and upwards.
I am hoping someone out there can give me some advice as I cannot bear another 60 minute+ wait to speak to someone at PlusNet.
Re: Plusnet Assist says it Doesn't Support My IE Browser
22-12-2013 3:35 PM
22-12-2013 3:59 PM
When you click on PlusNet Assist it states that it supports IE 6 and upwards so can't understand why it doesn't like ours!
22-12-2013 4:11 PM
23-12-2013 10:13 AM
talking about something else and I have misunderstood.
Select
Tools
Compatibility view settings. Then:
add this website to change compatibility view settings
https://pbttbcpn.bt.motive.com/portal/start.do
(which then appears just as motive .com in the list
without the front part)
and then after restarting it seems to work for me.
olly.
23-12-2013 10:16 AM
Intermittent faults can sometimes be difficult to diagnose. Do your disconnections happen at the same time? Is it every night? One of the first places to start would be to change the microfiter you are using, try to have the router plugged into the main 'master' phone socket and see whether anything electrical 'comes on' (heating, fridge, microwave ovens etc) at the time you start to have problems.
23-12-2013 10:18 AM
Quote from: ollyk I appear to have Plusnet assist working on IE11.
In compatibility mode eh? Thanks Olly, I didn't know that! Anyone else can confirm this works for them?
23-12-2013 10:34 AM
01-01-2014 1:17 PM
Thanks.
04-01-2014 7:47 PM
05-01-2014 9:14 AM
So if before you add motive
go to
Tools
Internet Options
Browsing History and untick the box where it says "Delete Browsing History on exit"
OK
Then try again to save the motive website.
At least for me it wont save when the box is ticked so the above may be why it wont for you.
Olly
05-01-2014 12:28 PM
Thank you for the reply. I did what you suggested and you were correct. I put that right and tried again, up came 'We have detected you do not have up to date PlusNet Assist' so I clicked the install now but it did nothing. So I found it on the main PN site and downloaded it from there. Then I had to uninstall Assist and have now re-installed it. Up came, you have guessed it!! We have detected you to not have up to date version....I give up for now, back to Sunday papers. When I lose my internet connection I will just do what Assist always says and turn off router and turn it on again. I know I have been advised in the past not to keep doing this as it apparently slows down the computer but can't see another alternative that I understand. thanks any way,
05-01-2014 4:30 PM
I think PlusNet assist is just another version of BT Desktop help.
Their is a removal tool written to remove various entries that may not be completely removed by just a standard de-install
which can be found at
http://pbttbc.bt.motive.com/motivedocs/discus/BTDesktopHelpCleanupTool.exe ; which you can then run or (save and run after)
So if you try an add/remove programs and remove plusnet assist
then run the above
then try re-installing it may or may not help. I am just assuming that many of the entries will be common to both PlusNet and BT.
Most forum experts don't like the software anyway but I just thought I would try to help.
If that doesn't work, then I think I would join you reading the Sunday Papers if I could justify the horrendous price they seem to be !!
Olly
05-01-2014 4:45 PM
Quote Plusnet Assist doesn't support IE10 or IE11 at present unfortunately. This is something we hope to resolve next year.
So if running IE11 in 'compatibility mode' - your reply #4 - doesn't work, then reinstalling is very unlikely to have any effect?
05-01-2014 5:33 PM
I run Windows 7 so perhaps it is something to do with which version of Windows people run.
The bit about the removal tool was from the BT forums where someone had a similar problem
with versions and this executable was meant to remove some registry entries relating to motive
which I thought might be relevant in silverfinches case as well. Perhaps not who knows !
was just trying to be of some assistance if I could.
Olly.
