BT Home Hub 5
jamesanstee
BT Home Hub 5
Mods feel free to move this if in wrong place .......
Has anyone managed to try out the bt home hub 5 on plusnets fttc service and how did the combined unit perform as im looking at purchasing one direct from the bt store but would like to know are there any pro's and con's IE are the sync stats viewable since it's a combined unit .
101 REPLIES 101
jamesanstee
Re: BT Home Hub 5
Also how easy is to configure to work on plusnet if it's compatible ? .
NorthEasterner
Re: BT Home Hub 5
Not used the new BT hub 5, even tho i'm on BT
here is a guide on how to set up the hub, that I created on Plusnet.  It should work on hub 5 even though it is appointed to the earlier models
http://community.plus.net/forum/index.php/topic,113872.0.html ; (another thread)
exact same information but from library
http://community.plus.net/library/hardware/using-a-bt-homehub-3-or-2-on-plusnet-adsl-or-fttc/
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
HNKS
Re: BT Home Hub 5
Anyone using this? I just bought one off ebay would like to know how it is.
NorthEasterner
Re: BT Home Hub 5
I'm in the process of getting the new hub 5 but near xmas time when the money starts to roll in from my bonus  Wink
So by the time I have one you would have probably set one up
I  am getting mine for £45 from BT (can't remember exact price but around that) I am an existing BT customer on infinity 2 (see my sig  Wink )
jamesanstee
Re: BT Home Hub 5
Hopefully i get my bt home hub 5 tomorrow £129 from the bt store will post more detailed info and user experience on it once i have it all setup.
NorthEasterner
Re: BT Home Hub 5
Are you on plusnet?
jamesanstee
Re: BT Home Hub 5
Yup im on plusnets unlimited fiber package.
wykehamhouse
Re: BT Home Hub 5
I'll hopefully be ordering one on in the next week or so so I'll give you my thoughts when I receive it.
NorthEasterner
Re: BT Home Hub 5
I'm going to do the dirty trick by ringing BT to cancel unless I get their new hub free
Fixes: 1,483
Re: BT Home Hub 5
mod:note
stripped the way off topic posts
jamesanstee
Re: BT Home Hub 5
Does anyone know if the home hub 5 has the broadcom chip.
wykehamhouse
Re: BT Home Hub 5
It does not.
NorthEasterner
Re: BT Home Hub 5
I'm guessing it would have a faster chip than the Broadcom chip.
wykehamhouse
Re: BT Home Hub 5
Nope, faster is the wrong word. It is pretty much the same speed as the equivalent Broadcom chip, just uses different hardware (Lantiq CPU).
dick:quote
