Transfering Photos from my Android Samsung Galaxy S2
tgr
I have photos on my mobile which i would like to put on to my apple mac PC but can't work out how to do it. Only just got into smart phones so if it is possible to do this step by step instructions would be appreciated. I have jelly bean op system on phone which i think is the latest system
12 REPLIES 12
w23
Fixes: 4
Re: Transfering Photos from my Android Samsung Galaxy S2
One way would be to set up Google Drive on both devices, photos can easily be transferred to Google Drive from an Android phone then accessed from another device with Google Drive installed.
http://www.google.com/intl/en_GB/drive/start/download.html
Call me 'w23'
Fixes: 385
Have a look at Airdroid http://www.digitaltrends.com/mobile/airdroid-how-to-wirelessly-connect-android-to-mac-or-pc/
tgr
airdroid downloaded but appears to be difficult to use to transfer pics although everyone seems to think it can do this easily  wish i had bought an iPhone it would have been so simple.  I am now reluctant to try the first suggestion of using google but may try that next
thanks for advice
Fixes: 385
I've just done it, albeit from my Nexus 7 to my office Windows box, can't see it being vastly different to your Mac.
Just run Airdroid on the phone, make the connection from a browser on the Mac, Open the 'Files' folder by clicking it, drill down to where your photos are ( mine are in the DCIM directory ) , select the photo(s) you wish to transfer and then click Download. If you select more than 1 photo it will download a zip containing all the selected photos.
NB the Airdroid desktop also has a Photos folder which should be the same as above.
edit: I've tried from my Nexus 7 to my Linux system at home using Firefox and that works just the same so I would assume the browser on OS X ( Safari ? ) should work.
knowdice
Doesn't your Apple have a USB connector?
Can't you just plug in the S2 and see it as a "drive"?
Fixes: 385
Nope. Android Jelly Bean doesn't implement USB Mass storage mode, it uses Media Transfer Protocol(MTP) mode. I'm not a Mac user but I believe MTP isn't supported natively by OS X yet. There are options to install software on the Mac to support it ( I think ) but from my experience I thought it would be easier for tgr to install Airdroid on the phone and keep the Mac standard.
tgr
Thank you everyone for your help.  I managed at last to get them uploaded using the air-droid prog :D.  I am over the moon just don't ask how I did I must have just pressed the right buttons Crazy
Fixes: 385
Glad we got you sorted. Smiley
w23
Fixes: 4
Quote from: tgr
Often the best way  Wink
I'd also like to thank MisterW, I didn't know about Airdroid but I do now.  Smiley
Call me 'w23'
MrT
A little late but could be of use to others - try Samsung Kies available at http://www.samsung.com/uk/support/usefulsoftware/KIES/JSP  Smiley
Kiyomi
I also have Samsung phone and I use Android Mobile Manager tool to transfer photos, it provides both Windows and Mac versions which support to transfer dtaa from Android to Windows or Mac, easy to use. How to transfer Photos/video from Android to PC.
Another choice is Android File Manager, both of them can be used to transfer data from Android to PC and transfer data from Android to Android.
heymao
As I know, transferring photos from your Android to Samsung Galaxy S2 is not difficult. We can use mobile phone transfer tool be our help. With its help, we can directly transfer photos between them after we connect both of them to computer via usb cables.
Moderator's note by Mike (Mav): Post released from Spam Filter
