How do i attach my speed test png image
Iain03
How do i attach my speed test png image to the bottom off my forums post next to my signature must be easy just can't see it, so it show's up all the time like a lot of other posts i see hope you get what i mean(is it ok to do this or do they prefer you not to clutter the page up).new to forums not new to plusnet.
Thank's Iain
7 REPLIES 7
Oldjim
Resting Legend
Fixes: 63
Re: How do i attach my speed test png image
Go to http://community.plus.net/forum/index.php?action=profile;u=8226;sa=forumProfile and paste in the link to the image
However you can't upload a picture to the system as it needs to be hosted elsewhere
Which speed test image do you want to use
This is a typical link where the code is [url=http://www.mybroadbandspeed.co.uk][img]http://www.mybroadbandspeed.co.uk/results/186798761.png[/img][/url]
Iain03
Thank's jim for moving my post to the right place I will get the hang of this, the image i want to use is from speedtest.net (i want to show how good my speeds are) Grin
I want to put it in the same position as your Old Harry Rocks in your profile if that is possible
Iain
Oldjim
Resting Legend
Fixes: 63
If you would like I can do it for you - just post the link here
Like this one http://www.speedtest.net/result/1050066775.png
Iain03
thank's Jim  http://www.speedtest.net/result/2580042460.png is this what you need or this
Thanks so much Iain
Gus
most speed test sites have a option to copy the code to post an image, that is what I do.  mark the complete code with your mouse and then press Ctrl and C to copy it to your pc's clipboard, then in a reply or new thread press Ctrl and V to paste it.
FTTP 500 regrade from Tues 28th November
Oldjim
Resting Legend
Fixes: 63
There you are
Iain03
Thank's alot Jim i see you're a very busy man, probably save me a lot of working out thanks as well Gus for the reply
