Gaming
- Gaming
- Gaming
Gaming
15-03-2013 8:51 AM
Re: Gaming
15-03-2013 10:20 AM
See this link, it should help.
Re: Gaming
15-03-2013 10:30 AM
Are you suggesting that the you are gaming, if someone does some youtube you have issues?
What games?
Ex-Broadband Service Manager
Re: Gaming
15-03-2013 11:00 AM
On Essentials both Gaming and Streaming are Gold, on Unlimited Gaming is Titanium and Streaming is Gold. I notice that 'Other' is Silver on both current products so misclassified gaming could get a lower priority.
Re: Gaming
15-03-2013 11:07 AM
Re: Gaming
17-03-2013 10:54 PM
Re: Gaming
18-03-2013 9:15 AM
Re: Gaming
18-03-2013 6:51 PM
Re: Gaming
18-03-2013 6:53 PM
LAN side he should have plenty of bandwidth, and ADSL side, we'll QOS the gaming above the streaming.
Re: Gaming
18-03-2013 8:04 PM
Re: Gaming
18-03-2013 9:10 PM
Re: Gaming
30-03-2013 2:43 PM
Quote from: Superted Youtube seems to be interfering with our games quite significantly, is there a list of games that you support? I wouldn't want to go on a pro package unless I was sure we would be gaining something.
I have exactly the same problem - any video streaming/large downloading and latency goes through the roof (100s of ms), rendering any of our online games unplayable. I'm in the process of having a form of error correction (called interleaving) switched off, as this can increase latency. The staff here can comment, but you could try having it disabled.
Re: Gaming
06-04-2013 12:13 PM
Re: Gaming
22-06-2013 12:04 PM
edit. "Second do NOT ever limit by MAC address unless you absolutely HAVE TO like netmask being broken or something, limiting by MAC has an extra overhead & does not reliably limit traffic on BOTH directions, netmask can & without the overhead. You can always set a static IP to your users' MAC so they have the same IP to avoid them changing IP to bypass QoS, to enhance on that you could also disable DHCP I believe it is so ONLY static IPs can connect, ie if they change their MAC to avoid the static IP to avoid QoS, the router will completely reject the connection. "
I found this a second ago, so don't hold what I say as correct. I will test out using ip instead of mac and see if there is much difference.
Re: Gaming
22-06-2013 12:49 PM
I found the DD-WRT firmware (supported routers only) to be very helpfull when using QoS. You set a max bandwidth and the QoS would share equally. If only one person was using the connection they would get the full limit you set. Then by setting the mac of my gaming pc to top priority, it could use the hole connection (no limit) and priority over anyone els.
