Could someone explain "gateway Hoping"
- Could someone explain "gateway Hoping"
20-02-2013 12:31 PM
Hi as it says above and also the benifits etc . seen alot on the forums about this so would like to try and understand what it is .
thanks
thanks
Message 1 of 8
(1,212 Views)
7 REPLIES 7
Re: Could someone explain "gateway Hoping"
20-02-2013 12:35 PM
It's hopping
On occasion, some of our gateways (the things you connect to to download stuff) become busier than others and by doing a soft disconnect and reconnect on your router, you should connect to a different one, which might be quieter than the other one. Sometimes this can improve your throughput speed.
Message 2 of 8
(693 Views)
20-02-2013 12:40 PM
Its disconnecting your connection to the gateway but NOT by rebooting the router, rebooting makes the BT system see a lost connection and will raise your snr and lower your IP profile if that happens too many times too quickly.
So most routers have a option to drop PPP connection or similar which the BT system doesn't react to, which if you are connected to a congested gateway will help by connecting to a different one eg faster/more stable download/upload speeds/no stuttering watching videos online.
FTTP 500 regrade from Tues 28th November
Message 3 of 8
(693 Views)
20-02-2013 12:44 PM
Thanks James an Gus , would this affect my gaming ? i mainly play BF3 on Xbox and lag can be a problem ,just to clarify "a soft Disconnect " is this done on the router web interface eg connect/disconnect ? (belkin) .
just to add does this affect fibre too as i,m due to get fibre next week ?
thanks again for the quick replies
Message 4 of 8
(693 Views)
20-02-2013 12:45 PM
Note that he said "Soft" disconnect - that means log into your (modem)/router, look for the section that covers your Internet Connection - PPP session - PPPoA may be another term used or PPPoE on Fibre, terms used are dependant on your (modem)/router. Look for the Disconnect/Connect, Drop Session button etc. - Disconnect, wait say 30 secs then Connect again.
Edit: Yes lag can be affected on a congested Gateway.
Message 5 of 8
(693 Views)
20-02-2013 12:47 PM
Thanks for the quick reply Anotherone
Message 6 of 8
(693 Views)
20-02-2013 12:59 PM
As a variant with my modem/router I haven't found a connect/disconnect option so I select "manual", save, select "always on", save - which does the same thing
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 7 of 8
(693 Views)
20-02-2013 1:10 PM
As long as it doesn't cause a drop of sync with the exchange!
Message 8 of 8
(693 Views)
