Saturday 21st November 2009Login | Register | Help
Pages: [1]
Automatic re-sizing of avatars
  • James_H
  • Guest
« on 04/04/2007, 15:48 »
Another minor niggle;
Its still possible to use a huge image for an avatar, which is downloaded in full and rendered as a smaller image by your browser.
The example I've added to mine is resized and thus appears to be a normal sized avatar, but is in fact a 3.7MB file. Get a load of them on a page, and folks could soon be wondering where all their http useage has come from.
A real pain if folks are having to use a slow connection to read the boards. (Could cost around £4 to view the avatar example I used if you were accessing via Post-Paid Orange GPRS - supposing you could have been bothered to wait for the download!)
One advantage of not using the re-sizing option is that large avatars can be identified much more easily and removed. This way its pretty hard.
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #1 on 04/04/2007, 16:30 »
That's definitely a problem.
Plusnet: Head of Platform and Operations
Logged
« Reply #2 on 04/04/2007, 16:57 »
You PlusNet avatar looks a little stretched.
Chilly
Forgive me Linus for I have; Vista
Logged
« Reply #3 on 04/04/2007, 17:45 »
PS - I'm gonna remove the silly size one now that the point has been illustrated. Wink
That's annoying, I can't tell if I've tweaked the configuration correctly or not :-p
Kind Regards,
Colin Ogilvie
Plusnet Application Developer (until June 12th 2009)
Get next generation speeds - Join the ADSL2+ trial!
Logged
« Reply #4 on 29/05/2007, 14:46 »
Think this works correctly, now.
Kind Regards,
Colin Ogilvie
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
