Download speed locked?
glloyd
Out of curiosity is my download speed locked? No matter when I connect the sync speed is always exactly the same.
10 REPLIES 10
penfold
Fixes: 5
Re: Download speed locked?
It may be banded, and you are syncing at the upper level of the band?Huh
x47c
Or the OP may be on the max possible 8128kbps on the ADSLmax service from the 20CN network.
jojopillo
Hi glloyd,
Yes, it looks like your line is banded, so I guess your sync has constantly been 14335. The banding will have been there for a reason but I can lift it and see what happens if you want?
Jojo Smiley
glloyd
Hi JoJo
Sorry for the late reply. I thought it might be banded but for why I don't know, I stay synced for hundreds of hours. It may be worth dropping the banding to see what happens.
orbrey
Hi glloyd,
That's been done for you, hope it improves things Smiley
glloyd
Thanks Matt extra 3 meg at the moment.
orbrey
Great news, hope it stays that way Smiley
glloyd
Can someone update my speed profile please. BT is showing 15.44.
jojopillo
HI glloyd,
I have raised your profile to 15400 to allow for your new BT IP profile. This should take effect shortly.
Jojo Smiley
glloyd
Thanks JoJo.
