Wednesday 19th June 2013Login | Register
Pages: 1 2 3 [4]
Akamai and streaming data - traffic management problem(s) are NOT fixed :-(
« Reply #48 on 26/02/2012, 08:27 »
Should probably define my testing logic here, as PCs can be fickle things ...
My netflix viewing is on a HTPC in the lounge, and as with all things, you can never be 100% sure that it might not be the culprit.
When it pauses streaming badly, or falls back to a horrible netflix quality level, I stop it, and run up netflix on a 2nd pc,  with wireshark installed.
If this 2nd client shows a bitrate problem (via the Sliverlight diagnostics), I think its fair game for a slowdown report.
If it doesn't , then the HTPC could be the suspect in this case, or of course the slowdown could have been a very short blip
However, this scenario hasn't happened yet. The 2nd pc always reflects what the htpc sees (so far) ...
Logged
« Reply #49 on 26/06/2012, 20:23 »
Netflix quality problem tonight ( ptn-ag03)
Cannot reliably get a HD stream from Netflix, and the DSF seems to be running at 0x60 ?
general connection seems as per normal (20CN)
« Last Edit: 26/06/2012, 20:26 by Roswellgrey »
Logged
« Reply #50 on 26/06/2012, 21:13 »
I cannot always get a full BBC SD download before midnight.
I don't think line speed comes into it.
See https://support.speedtest...e-netflix-video-games-etc
« Last Edit: 26/06/2012, 21:19 by Un renard, c'est le Mal »
Support via Land-line 0800 432 0200
Logged
  • Kelly
  • Plusnet Staff
  • View Profile
« Reply #51 on 26/06/2012, 22:31 »
What Gateway are you on Foxy-evil?
Plusnet: Head of Products and Digital Care
Logged
« Reply #52 on 27/06/2012, 08:10 »
Sorry - my post was a bit too concise for its own good Smiley
What I meant was that my line speed was as per normal (8Mb max) , and I normally can stream HD from netflix with no problems at all.
Last night, however, something upstream of me was either running out of puff, or the stream was being incorrectly traffic managed ...
Logged
« Reply #53 on 27/06/2012, 10:17 »
I'm currently on:-
You are currently connected to the gateway known as ptn-ag01.
This is located in Telehouse North.
Logged
  • dave
  • Plusnet Staff
  • View Profile
« Reply #54 on 27/06/2012, 16:53 »
Have you recently started using Netflix? We're in the middle of upgrading our traffic management platform; our old platform on one or two of our older products doesn't correctly identify Netflix and you might see issues in the evening. It works fine on the new traffic management platform, it's just a the old one that's affected. If you disconnect and reconnect and hit one of these gateways:
pcl-ag03, pcl-ag04, pcl-ag05, ptw-ag01, ptw-ag02, ptw-ag03
It should then work fine. The rest of the network is being moved across in stages to the new platform so it should be fine everywhere once we've finished across all products.
Regards,
Dave Tomlinson
PlusNet Products Team
Logged
« Reply #55 on 27/06/2012, 19:10 »
Dave - I have been using Netflix for months, and am one of the regular moaners when it doesn't work Smiley
Will do a gateway hop and see what happens.
Thanks for the info ...
Logged
Pages: 1 2 3 [4]
Jump to:
Related Sites
Community Apps
About Plusnet
We're a Yorkshire-based provider selling broadband and phone services to homes and businesses throughout the UK. Winner of the ISPA 2010 'Best Consumer Customer Service ISP' Award, we're proud to offer the UK's best value standalone broadband.
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
