Pro add on worth it?
- Pro add on worth it?
08-09-2011 8:14 AM
Im wondering if Pro Add On is worth it for me.
My wife and I are not gamers nor work from home,so mostly general browsing plus streaming together with up and downloading.
I realise the Add On is on a monthly contract .
My speed is poor at present always has been
Message 1 of 3
(1,096 Views)
2 REPLIES 2
Re: Pro add on worth it?
08-09-2011 9:25 AM
Hi anniesboy,
The add-on won't give you faster speeds, if those are an issue then I'd advise raising a fault with us: https://portal.plus.net/apps/kbdfaults
From you're described usage I don't think it would be much of an advantage but you could try it for a month and see how it goes.
Message 2 of 3
(525 Views)
08-09-2011 10:11 AM
It wont really benefit you tbh mate, i had it for gaming years ago when it first come out worked well
Message 3 of 3
(525 Views)
