Wednesday 10th February 2016Login | Register
Pages: [1]
Waitrose POP3 email problems
« on 15/12/2010, 13:14 »
Since early today I have been unable to send emails using POP3 on my Waitrose account.
I get the following error message:
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'xxxxxxxxxxxx@waitrose.com'. Subject 'test', Account: 'xxxxxxxxx', Server: 'smtpmail.waitrose.com', Protocol: SMTP, Server Response: '550 relay not permitted', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
I have replaced personal info with xxxxxxxxxxx
Webmail works and incoming messages are getting through.
Any ideas please?
Dennis      ---    Plusnet Unlimited & Talk Anytime
Logged
« Reply #1 on 15/12/2010, 13:21 »
Hi Dennis,
I've asked Bob to have a look into this one, but that message is normally when you are trying to use an outgoing mail server that does not belong to your connection.
I take it you are currently connected to your Waitrose Broadband service?
Logged
« Reply #2 on 15/12/2010, 13:34 »
Are you trying to send using your Plusnet connection Dennis? If not, that's probably what the issue is. I've just tried sending an email from your account and I didn't experience any problems:
Code:
$ telnet smtpmail.waitrose.com 25
Trying 212.159.8.242...
Connected to smtpmail.waitrose.com.
Escape character is '^]'.
220 smtp-proxy02.plus.net ESMTP Exim Wed, 15 Dec 2010 13:26:09 +0000
ehlo waitrose
250-smtp-proxy02.plus.net Hello waitrose [84.93.217.165]
250-SIZE 52428800
250-PIPELINING
250-AUTH LOGIN
250 HELP
mail from:<***************@waitrose.com>
250 OK
rcpt to:<support@plus.net>
250 Accepted
data
354 Enter message, ending with "." on a line by itself
subject:test
250 OK id=1PSrNW-0002nn-F5
quit
221 smtp-proxy02.plus.net closing connection
You'll probably receive the auto-responder.
Logged
« Reply #3 on 15/12/2010, 14:27 »
OE6 servers setting is showing   smtpmail.waitrose.com which I thought was right and has always been set to that both in my Greenbee & PN days.
I have only a Waitrose PAYG account just so I could keep my Waitrose email address. My only BB connection is my PN one.
Logged
« Reply #4 on 15/12/2010, 15:36 »
That server address should be fine from a PN connection. In fact I've just tried sending an email from your account using my home Plusnet connection and I didn't encounter any problems.
Open up a command prompt and type.
Code:
Press enter and you should get:
Quote from: Waitrose SMTP server
220 smtp-proxy03.plus.net ESMTP Exim Wed, 15 Dec 2010 15:23:44 +0000
Type:
Code:
ehlo waitrose
250-smtp-proxy03.plus.net Hello invalid.tld [80.229.xxx.xxx]
250-SIZE 52428800
250-PIPELINING
250-AUTH LOGIN
250 HELP
Type (substituting 'your_email_address' with your actual email address):
Code:
mail from:<your_email_address>
250 OK
Type:
Code:
250 Accepted
Type:
Code:
data
Type:
Code:
Test
Press enter, then type a single dot.
Code:
Press enter and you'll get something like this:
250 OK id=1PStDn-0006qc-Q0
Type:
Code:
quit
Press enter and you should get something like this:
221 smtp-proxy03.plus.net closing connection
Connection to host lost.
If any of the above fails, let me know at which point and what it says and we'll take it from there.
Logged
« Reply #5 on 15/12/2010, 17:20 »
Bob,
After rcpt to:<support@plus.net>   I get 500 relay not accepted
« Last Edit: 15/12/2010, 19:00 by reserved »
Logged
« Reply #6 on 15/12/2010, 17:28 »
I have rebooted and changed my IP from 84.51xxx to 91.125 xxx and it now seems to work  Huh?
Logged
« Reply #7 on 15/12/2010, 22:18 »
That was going to be my next question Wink
Will be interesting to see whether or not you have problems the next time you're assigned a similar IP?
Logged
« Reply #8 on 16/12/2010, 08:01 »
One step ahead of you Bob  Wink
edit: I'm still on 91.125xxx this morning and it's still working!
Watch this space
 Undecided
« Last Edit: 16/12/2010, 08:05 by reserved »
Logged
Pages: [1]
Jump to:
Related Sites
Community Apps
About Plusnet
We're a Yorkshire-based provider selling broadband and phone services to homes and businesses throughout the UK. Winner of the ISPA 2010 'Best Consumer Customer Service ISP' Award, we're proud to offer the UK's best value standalone broadband.
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Add to Technorati Favourites
